- Identify the wires (pos and neg) by testing on a battery or 12 volt source. You can't damage it. I can only see a black wire and I'm not willing to bet that it's the earth wire
- Take the cover off the tail hump
- connect the earth wire to the brown wire
- connect the positive wire to the slate/yellow wire (grey with a yellow tracer, if you like)
Job done.
If you're talking about physically mounting it,
- see where the bracket sits in relation to the lower edge of the numberplate with the light along the lower edge of the numberplate
- mark the mudguard
- offer up the bracket to the same position
- drill holes as necessary
- you may need to drill the numberplate too to put bolts through both items and ensure it will sit back where it came from
-- alternatively, mount the bracket to the mudguard using dome head allen bolts because they are fairly low profile
-- remount the numberplate with double-sided tape which should be thick enough to clear the dome heads
[Edited in line with Duck's correction. Gah. I blame the 10yo port and the fact that I couldn't be bothered to find my glasses when looking at the wiring diagram]
