1 Speedometer quit while riding, Weller iron Sat Aug 12, 2023 11:22 am
lucki
Went for a 200km spin yesterday, all well, halfway through trip Speedo quit. Then close to home it worked all the way back.
Did a search and did the soldering gun thing, the Speedo registered. However, with the soldering gun humming away and the Speedo needle showing about 40kph, I stared wiggling wire connections, all fine. Then gave the Speedo cluster a tap, speedo quit. I assume it is a bad connection in the cluster. What connections are likely at fault? I have the k75s, is there an easy way to get at the back of the cluster?
