1Back to top Go down   '94 K75RT relay numbers and position Empty '94 K75RT relay numbers and position Wed Feb 08, 2023 10:47 am
beemerguru
beemerguru
This is frustrating. I just repaired 2 early K bike electrical problems and can't fix my own 1994 K. This is the series with the 4 little relays.
Starter works, no fuel pump. Wire the #6 fuse to the battery #, the pump runs, and the bike starts. Thinking it was the fuel pump relay. Pulled the relay holder to check the connections on the bottom, then swap the relay, no joy.
Then stupidity stepped in and swapped the other 3 relays trying for a quick fix..which means everything is messed up. Yep, can fix everyone else's bike except your own.
I can't find any diagram or parts explosion that shows the relay number AND relay location. I know it's only 4 relays but now I have 8 little relays and they all have different part numbers.
https:// https://airheadadventure.com/
'94 K75RT relay numbers and position V2CWByS
'94 K75RT relay numbers and position Relayb2
Fuel, horn and load shed use the same relay. 61311459677
'94 K75RT relay numbers and position 677relaytop
3Back to top Go down   '94 K75RT relay numbers and position Empty Thank you Wed Feb 08, 2023 12:13 pm
beemerguru
beemerguru
So I can toss the 412 that somehow got into the mix. All 3 of the black relays are 677.
61311459677 is a four-pin make-only relay. The good thing about these is that you can fit a five-pin changeover relay in the same slot and it willl work equally as well; the middle rear 4.8mm terminal just isn't used or connected up. So if the 412 has five pins and the picture on the side shows a changeover configuration, don't toss it but keep it for a spare.
