1 K1100RS fairings on a 1985 K100RS. Tue Feb 28, 2023 1:16 am
RS Rider
I’m sort of kicking around the idea of sourcing K1100RS fairing parts for my bike as I really like the look. At this point, I’m just gathering information and thinking about it. Going through the parts fiche, I see that it actually came as a kit/upgrade way back when.
The upper fairing and rad trim panel are common between the 2 models, so it would appear to be straight forward as all the mounting points would line up. But I have a couple of questions for those with far more knowledge than I.
1. The left and right knee pads are different parts between the 2 models, but it appears as though the K100RS knee pads will fit the K1100RS left and righty lower fairings. Correct?
2. The belly pan attachment is different, so I would also need the bracket that attaches the rear underside of the belly pan to the engine?
As long as the left and right lower fairings are complete, I need 4 pieces-belly pan, belly pan mounting bracket, and left and right lower side panels.
