1 Replacing HES sensor on existing K75 plate. How to rivet on the replacement? Sun Oct 09, 2022 10:22 pm
I'm helping a friend with his K75. I've determined that one of the Hall effect sensors on his bike is failing, the other is good. I have a spare K100 HES plate with two operational Hall effect sensors. I'd like to replace the failing sensor on the K75 plate with one of the operational ones from the K100 plate.
I know to remove the failing sensor, I have to grind down the rivet to the plate and then knock out the old sensor. However, best practice is to insert a brand new sensor and peen over its rivets with a tool. Anyone have a suggestion how can I fasten the replacement I have to the K75 plate?
