1Back to top Go down   New K-bike owner says hello Empty New K-bike owner says hello Mon Sep 19, 2022 6:45 pm
taube
taube
Hello everyone,
Pleased to be part of the forum. This year I picked up a 1988 K100RS that the previous owner had neglected outdoors for 4 or 5 years. I'm getting it back into riding-condition.
I lurked the forums previously and found very useful advice already. For example, my fuel tank cap lock wouldn't open -- some threads here helped me overcome that issue! Cheers all, looking forward to getting my flying brick running!
2Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Mon Sep 19, 2022 9:42 pm
Welcome to the Forum
post a couple of pics
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
3Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Tue Sep 20, 2022 9:22 am
fishboy316
fishboy316
Hello!
4Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Wed Sep 21, 2022 1:23 pm
taube
taube
Thanks for the welcome. Nice to see a fellow Marylander, fishboy316
I'll post a few pics of work I've done on the K100RS so far
Fuel tank cap: The lock was toast. Drilling a hole to reach the bolt sort of worked, but the bolt was rusted so badly it wouldn't pull back easily. Luckily I forced the lid open without damaging the tank. Then I had to remove four screws fastening the cap to the tank. They were so rusty that any bit immediately stripped the heads. I had partial success with a screw extractor bit set I got for $14 on Amazon. It ripped the screw heads off and left the threads in the tank, but that was enough to get the cap off.
New K-bike owner says hello XjwOpxe
5Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Wed Sep 21, 2022 1:37 pm
taube
taube
Here's a photo of the bike loaded up for transport, back when I got it from the previous owner
New K-bike owner says hello HyWjdYU
6Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Wed Sep 21, 2022 4:25 pm
fishboy316
fishboy316
What area are you in? Your bike has the makings for an awesome ride!
Took mine to bike week last week. She got a lot of looks but was mostly Harleys.
7Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Wed Sep 21, 2022 4:54 pm
RS Rider
RS Rider
Those Special Edition RS's looked sharp. Too bad the previous owner neglected it, leaving it outside. Hopefully it cleans up into a head-turner for you.
8Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Wed Sep 21, 2022 10:45 pm
Bricklayer
Bricklayer
Congrats!
A definite project. 1st owner of my K100RS let it sit in a garage (luckily) for 10 years. Replaced just about everything rubber but in hindsight I would have also changed the steering head bearings. I found out what a thrill a tank slapper was one day...
I had a rusted screws in my gas cap retainer ring also. Thread re-tapped but iffy, so I put in longer screws (and anti-seize). I could measure the longer ones if you like.
https://anthonymrugacz.net/
9Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Thu Sep 22, 2022 10:46 am
taube
taube
fishboy316 wrote:What area are you in? Your bike has the makings for an awesome ride!
I am based in Baltimore but my bike garage is in the College Park / Greenbelt area.
RS Rider wrote:Those special edition RS's looked sharp.
Agreed! I actually just have a regular K100RS with same paint job.
Bricklayer wrote:I had a rusted screws in my gas cap retainer ring also. Thread re-tapped but iffy, so I put in longer screws (and anti-seize).
I'm not familiar with thread restoration so I'm kind of confused what this means. Did you drill out the original screws then try re-tapping the holes? I could definitely use advice on that.
Great advice on the steering head bearings btw study
Restoration project: 1988 BMW K100RS
Currently riding: 2019 Honda CBR300R
10Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Thu Sep 22, 2022 11:06 am
Bricklayer
Bricklayer
No advice on getting them out other than I  soaked my 1 stuck screw with penetrating fluid over night and used a good amount of downward pressure as I unscrewed it as not to strip the phillips head. Corrosion made the thread hole a bit funky so I cleaned up the threads with an original size tap it and used a "tad" longer screw to get to the the threads that weren't damaged while sitting in contact with the original length screw.
Original screw length total = 10mm.
Just measured and I have 13mm length screws
11Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Thu Sep 22, 2022 12:07 pm
Bricklayer wrote:No advice on getting them out other than I  soaked my 1 stuck screw with penetrating fluid over night and used a good amount of downward pressure as I unscrewed it as not to strip the phillips head. Corrosion made the thread hole a bit funky so I cleaned up the threads with an original size tap it and used a "tad" longer screw to get to the the threads that weren't damaged while sitting in contact with the original length screw.
The first thing to do is clean out the Phillips head with a tack or dental pick or whatever to ensure that the screwdriver head gets all of the way in. Then, as you suggest, use a GOOD Phillips screwdriver with lots of downward pressure.
I replace my gas cap screws with stainless hex screws.
New K-bike owner says hello Others4
To get even better anti head strip protection you could use Torx screws.
12Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Sun Sep 25, 2022 9:33 am
Bernie_K100
Bernie_K100
Hi,
New K-bike owner says hello 177912 to this forum!
Bernie
13Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Sun Sep 25, 2022 1:26 pm
Bricklayer
Bricklayer
Griaß God!
14Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Sun Sep 25, 2022 5:17 pm
Welcome Taube Smile
New K-bike owner says hello Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
15Back to top Go down   New K-bike owner says hello Empty Re: New K-bike owner says hello Tue Sep 27, 2022 1:49 pm
bad boy
bad boy
hi taube
New K-bike owner says hello 177912 here
Cheerz, David
New K-bike owner says hello 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
