1Back to top Go down   I need Help for my K1100Lt   Please Empty I need Help for my K1100Lt Please Wed Sep 21, 2022 9:24 pm
wilsonneves
wilsonneves
Hi all
I would like you can help me..
I have a BMW K1100LT
I bought Material MotoGadget as: Motoscoup Pro + Breakout Box B + Mo.Unit Blue
So far we've had an error that we haven't been able to figure out how to solve... Motoscoup Pro doesn't detect gasoline, how do I detect gasoline?
Now, will the rotations work? Will the speed sensor work? temperature ones Will they work?
Is there something that can help me understand to see if I can get this situation resolved, as I've had the bike open for 3 weeks and I don't know what to do.
Thank you so much
Wilson
Here we are expert om BMWs if you need advice on Motogadget I suggest you ask the makers of the product.
3Back to top Go down   I need Help for my K1100Lt   Please Empty Re: I need Help for my K1100Lt Please Wed Sep 21, 2022 10:12 pm
Motoscope manual:
FUEL This function requires the motogadget Breakoutbox A or B (article no. 1005040 or 1005041) and a vehicle built-in fuel sensor with a 0-500 ohms measurement range.
K bike fuel level sender goes from 110 ohms empty to 3.5 ohms full.
If your tank is empty then the Motoscope probably would show about 1/5 tank. When the K tank is full the Motoscope would probably show empty.
wilsonneves
wilsonneves
Thanks for your reply…
But I use the same sensor (original) ?
For a correct reading what I need in my k1100 ?
Thank you 🙏🏼
The gauge expects Japanese style fuel senders (0 - 500 ohms) and you have German (110 -  2 ohms). Read my article on 'Messing with the in-tank fuel sender" to see how to modify it.
yes, rpm should work.
no, the manual specifically states that the gauge is incompatible with 2-wire variable reluctance sensors.  You have to convert it using an electronic circuit like Brotbox or my TGPI board.
no.  There is no oil temp sensor on the k1100.  There may be an optional water temp sensor for the aux. gauges on the k1100lt that you can try.  It's mounted in the water pump.
no.  This is something you have to work out on your own through research.  There's no quick guide to download AFAIK.
wilsonneves
wilsonneves
Hi
@robmak
White is It ? “Messing with the in-tank fuel sender”
Thank you
Click here, Wilson.
Bernie_K100
Bernie_K100
Hi Wilson,
I need Help for my K1100Lt   Please 177912 to this forum!
Bernie
