Problem "solved"? Okay, I got a new multimeter with an amperage function that works, removed all fuses and put the meter inline between battery and ground, determining that there was a 0.8 amp current with just the top fuse installed. That's a R/Y = red and yellow wire, which supplies the relay for the Motronic unit. Removed that fuse, installed just #5 (R/W = red and white wire, goes to bulb monitoring unit, and clock) to also find 0.8 amp current. Installed both the above fuses = 1.6 amps current. That "sort of" makes sense I thought, because that's a substantial current and when I installed the new battery there was a nice spark at the terminal which I thought strange but figured some capacitance somewhere was charging up. None of the other fuses, installed alone, resulted in any current. Scratching my head and looking at the engine and frame wiring diagrams I could not figure any common load-drawing relay or device between these two fuses/circuits. So I resorted to direct exam and exposed and checked every connector. No bare wires, no cracked insulation. There sure is a mess of wiring and connectors packed and cooking under the tank, though, not my idea of good design really. Note the above readings were obtained both with and without the instrument cluster installed. I took the amp-meter out of the circuit, reconnected the battery, and turned the ignition switch (key) on and off a few times and leaving it on felt each relay for any heat. None. Said "Well I'll be dammed" and I've monitored battery voltage for over 16 hours now and it's 12.90 volts and holding. There is no more drain with the ignition off. I'm happy, but would rather have found a source of the problem. Thanks all for your thoughtful and helpful input. Ride safe.
