SunnyPerth
SunnyPerth
Hi All,
Looking for a K100RS Two Piece Front Fender & the brace, preferably in or near Perth Australia, or alternatively in Seattle. (As I will be there in a few weeks).
(I do have a sports front fork with the lower tubes having the provision for a brace, this might well be from an K75. Not sure if the forks are further apart between those two models (k75/k100) I can measure up if needed, so we can check it’s the right brace/fender)
Let me know if you have anything?
Cheers, SunnyPerth
The two-piece front mudguard will fit any version, from the K75S sport fork, most K100 from about '87 on, as well as K1100, regardless of fork brand. I have several pieces, in good nick, and different colours, with mounting plate. Gimme a PM when you're in Seattle. I am 50km south of the big smoke in a suburb of Tacoma.
The front halves are all the same and I'm not sure what the difference is but the K100RS4V & K1100RS have a different rear half (46612309126) than the K75s/K100s (46611453967) Probably to deal with the wider front tie on the 4V RS bikes.
Also the Showa forks have a different fork brace:
K100RS Two Piece Front Fender +brace  LHoESwR
SunnyPerth
SunnyPerth
Hi all, just to let you know I now have the bits I needed. Thom at Kpartsholland had them for me. Cheers, Yuri
