I few K Kronies are requiring a workshop day. Due to Matt and Gary going on a Kurfari in early August I thought probably late August and on a Sunday. Please let me know what jobs you require doing and if you are attending?
2Back to top Go down   Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Empty Re Workshop Day Thu Jul 14, 2022 10:26 am
Bruce Petterson
Bruce Petterson
Hi Martin.   Grease the shaft is my work that is needed.    Thanks again.
I will be attending.   What day/date ?
Kind regards Bruce
Bruce Petterson wrote:Hi Martin.   Grease the shaft is my work that is needed.    Thanks again.
Kind regards Bruce
 Geez what sort of workshop is this when people are getting their shaft greased  ???
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
Matt are you volunteering to grease Bruce's shaft. Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. 723598 He will be supplying his own grease.  Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. 652573 Due to you having to work in order to support SSD and I I've made it on a Sunday and at the end of August. Will you be attending?
Mick67
Mick67
Thanks Martin.
I will be attending. Thinking about an instrument cluster overhaul - GPI and Clock displays bleeding, sticky speedo and clunky tripmeter gears, also a good clean up as hasnt been opened since I've had it - 18yrs.
Might take me some time to gather parts, so may not be ready for the day.
Happy to assist others as required.
Mick
K100RS 1984
VIN 0013414
Mick I have the parts.
Mick67
Mick67
Goodo. See you then if not before. We'll work something out re parts.
Mick
K100RS 1984
VIN 0013414
8Back to top Go down   Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Empty Parts Thu Jul 21, 2022 2:41 pm
Bruce Petterson
Bruce Petterson
Of course Martin has the parts . . . He could jolly near build another K bike with all the parts he has.
Bruce
Kind regards Bruce
That's them Northerners, Matt.  Theys always was a bit funny.
You're safe with us Southerners in the chain gang.  Weez just like to get lubricated.   (o)
Due to Matts busy schedule he is unable to attend any of the proposed dates. So at this stage it is planned for the 28th of August. I'm currently awaiting speedo gears which should hopefully be here by the 28th. Proposed works are two speedo overhauls and a driveshaft spline check and grease. If any other Kronies require work or are attending please let me know so Bruce's lovely  wife and my lovely wife can work out the food. Attendees at this stage Dan, Mick, SSD, Bruce, Vic.
Jamie64
Jamie64
Hi Guys
I will be there to assist with anything i can.
If we have time i too could do with a spot of grease in the tail section.
Chears Jamie
Bugger
I Cant make the 28th
1988 K100 RS SE
The guest list is as follows Kronies requiring work Mick, SSD, Jamie and Bruce. Kronies assisting Dan, Gary, Vic, Geoff and myself. If I've missed anybody please let me know. scratch
Start time 0800 to 0830.
15Back to top Go down   Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Empty Short Workshop Day Thu Aug 25, 2022 4:57 pm
Bruce Petterson
Bruce Petterson
Shit Martin.   Half an hour.   That would be the shortest workshop day ever.   I'd be luck to get mine on the main stand and the back wheel off in that time and the workshop is over ????
lol!
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. 161205 Start time.
17Back to top Go down   Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Empty Workshop Day Fri Aug 26, 2022 2:17 pm
Pegasus
Pegasus
Sorry, I'm out now.
My daughter is sick, so I'm looking after my grandson for the weekend, so she can get some rest.
GB777
GB777
Jamie, i'll bring the large Allen Key (1/2" Drive) and the large socket required to remove the Paralever Final Drive.
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
We had another successful workshop day with 10 bricks in attendance with  an interesting start. I received a call off Jamie saying he had broken down about a Km short of my place. He said it looked like the fuel pump. As my bike was blocked in chucked some jumper wires, multimeter and a circuit tester and ran out. After a bit of probing and a call out for a workshop manual it was deemed that there was no power between the fuse and the pump connector. A jumper wire allowed it to be ridden to my place. Jamie will fill in on what happened next along with the others posting what work they had done. Everybody happy with the work accomplished.
Butcher Bird pit crew.
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. P8280010
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. P8280011
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Img20210
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Img20211
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. P8280012
20Back to top Go down   Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Empty Workshop Day Sun Aug 28, 2022 5:06 pm
Bruce Petterson
Bruce Petterson
Thanks again Martin for yours and Anne's hosting today for another successful workshop day.    It was a great turn out - all of banter, fun and good food.    Thanks once again.
Had a look on Gumtree and Ebay to try to find that final drive.   Cant see it anywhere.
You may have to guide me in regards to me putting a NEW post on the Forum asking if anyone in Aust has one or knows of someone that may have one.
Regards Bruce
It looks like it's gone or he's pulled the listing. I'll PM you his number.
Mick67
Mick67
Many thanks again for hosting Martin and for having available all the 'bits and pieces' that make working on our K's that bit easier.
The knowledge and willingness to help in this group is outstanding. I think in the 5 hrs or so, the group completed 2 final drive lubes and diagnosis, 2 Instrument panel dismantles and overhauls, and an unexpected clutch cable/switch repair. As well Martin squeezed in a roadside fuel electrics diagnosis and repair.
Most jobs were done at least twice (just to make sure). All work was scrutinised, critiqued by the elders and where appropriate, public humiliation and ridicule were used as effective teaching techniques. The healthy dose of questionable humour and the outstanding morning tea made for a most enjoyable morning.
As far as I know all bricks were able to leave in working order, so a good result.
See you on the next one.
K100RS 1984
VIN 0013414
StandardK
StandardK
Many thanks to the dynamic "A-team" duo catering for the mob, the sausages & rolls were smashed
As previously posted by our resident serial pest Mick I agree, always satisfying when all the bricks arrive & depart in one piece & running.
Any odometer repairs carried out have the usual "3KM/3min-whatever comes first" warranty, now expired
Well done & thanks to our esteemed leader/therapist Martin for organising the day & keeping the unruly attendees under strict control, glad he enjoyed hearing Jamie's RS "unrestricted" exhaust for a very short period...sounded mean
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Screen27
Dan go bye-bye under the land barge, the Admiral supervising Jamie sleeping under his RS, Martin supervising Admiral supervising Jamie, Vic looking on with disdain
Regards
Dan
Regards
Dan
GB777
GB777
Big thanks to Martin, Ann & Annie for providing great food and the venue, it was another successful Service Day for the Kweensland K100 Forum members. A welcome to Geoff on his maiden event with the forum group of mis-fits.Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic10
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic11
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic12Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic13
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic14Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic15
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic16
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic17Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic18
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic19
Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic20Successfully Completed SE Kweensland K Kronies WorKshop. 28th of August. Servic21
Gary
