1Back to top Go down   K75 rear wheel Empty K75 rear wheel Mon Apr 11, 2022 7:14 pm
arbalest
I have a K75 18" drum brake rear wheel. Was there ever an 18" disc brake rear wheel?
2Back to top Go down   K75 rear wheel Empty Re: K75 rear wheel Mon Apr 11, 2022 8:27 pm
No they were all 17"
3Back to top Go down   K75 rear wheel Empty K75 Rear wheel Mon Apr 11, 2022 8:31 pm
arbalest
Thanks.
4Back to top Go down   K75 rear wheel Empty Re: K75 rear wheel Tue Apr 12, 2022 11:53 am
Yes, there is an 18" (three spoke) rear wheel to fit 16V K100 & K1100RS with Paralever which can also be used where a 17" (Y spoke) disc brake rear wheel is used such as K75S, RT models & K100. It won't fit your drum brake equipped K75 due to offset, & etc., unless you source a final drive from a Monolever/Paralever (which opens an entirely new thread) to accommodate it.
5Back to top Go down   K75 rear wheel Empty K75 wheel Tue Apr 12, 2022 4:32 pm
arbalest
Two Wheels Better wrote:Yes, there is an 18" (three spoke) rear wheel to fit 16V K100 & K1100RS with Paralever which can also be used where a 17" (Y spoke) disc brake rear wheel is used such as K75S, RT models & K100. It won't fit your drum brake equipped K75 due to offset, & etc., unless you source a final drive from a Monolever/Paralever (which opens an entirely new thread) to accommodate it.
I want to use the Y spoke wheels as I have a rear wheel and a front wheel. I'm looking for a matching wheel for the sidecar.
