1Back to top Go down   Space between the pad and rotor Empty Space between the pad and rotor Sat Jun 04, 2022 8:04 pm
bmwk100rs
bmwk100rs
My rear brake pads are riding up against the rotor at all times, but I can still easily rotate the rotor by hand and the pistons extend to stop it when I press the brake pedal. Should there be a gap between brake pads and rotors?
Space between the pad and rotor Img_2614
Space between the pad and rotor Img_2615
2Back to top Go down   Space between the pad and rotor Empty Re: Space between the pad and rotor Sat Jun 04, 2022 8:39 pm
It sounds like all's right with your world, brake-wise. Smile
3Back to top Go down   Space between the pad and rotor Empty Re: Space between the pad and rotor Sat Jun 04, 2022 8:57 pm
moriarti
moriarti
Without the GAP the brakes are ON. MIND THE GAP PLEASE cheers cheers
JOKING apart the gap is very small reducing piston movement to a minimum, ALL is well
