1Back to top Go down   Low compression on K75 Empty Low compression on K75 Sat Mar 12, 2022 5:32 pm
Nom721
Nom721
I’m getting towards the end of a major restoration of my K75 and was starting up for the frist time in a very long time. I was a bit ancious to push the starter button but after a couple of revs it started to fire, erratic but it ran Laughing
I turned it off and decided to do a compression test. Cyl 1 and 3 both did about 10 bars but no 2 only did 4-5 bars. I guess that’s the reason for the bad running. The question is now what is the most likely reason for the lack of compression? Where would I look  first?
2Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Sat Mar 12, 2022 5:52 pm
Check valve clearances to begin with.
Can you do a leak down test, which might be more telling than a compression test?
3Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Sat Mar 12, 2022 5:59 pm
Nom721
Nom721
I will have a look at the valve clearance. How do you do a leak down test?
4Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Sat Mar 12, 2022 6:08 pm
Nom721
Nom721
Just found an article about leak down test. Try that as well.
5Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Sat Mar 12, 2022 7:16 pm
moriarti
moriarti
Inject some light oil into No 2 then compression test again if its now good as others Suspect sticking piston rings which will free off with running HOPFULY Very Happy Very Happy
if
6Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Sun Mar 13, 2022 1:37 am
Sticky piston rings are very high on the suspect list after a long lay down.
Valve clearances are so very easy to check. If you are doing it be very careful retorquing the cam cover bolts, the torque setting is extremely low.
7Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Sun Mar 13, 2022 1:02 pm
And replace the rubber bungs under the cam cover bolts. If you don't, you'll end up with a multiple Texas gusher.
8Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Tue Mar 15, 2022 3:23 pm
Nom721
Nom721
Just did the oil in cylinder trick which restored the compression Laughing It still runs shitty, will do ignition timing, balance throttles. Hope that will do the trick..
9Back to top Go down   Low compression on K75 Empty Re: Low compression on K75 Tue Mar 15, 2022 4:05 pm
moriarti
moriarti
Good news on the (oil trick) now treat the K to a set of BOSH spark plugs. No WORRIES. Razz Razz
