1Back to top Go down   ICU overheating? Empty ICU overheating? Tue Jan 18, 2022 6:07 am
Alzaboy
Alzaboy
Do 100ml and then my bike cuts out won't start change the ICU unit to another one and it starts up no problem same thing again 100 mi cutout change ICU and it will start again why can anyone give me why that does this k100lt 1989.
2Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 7:09 am
To make sure it is an ICU overheating problem try hitting it with a shot of Freeze Spray. Available at electronics stores.
3Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 7:20 am
moriarti
moriarti
scratch Hi mate,just to be clear,have you 2 ICUs that you change over  or a large shed full. Smile
For 2 units to fail in the same way points to a problem causing this to occur. At the point of failure was the unit hotter than one would expect, poor airflow, excessive, engine heat, When unit one has cooled down then refitted does it work or not. scratch
4Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 7:38 am
Alzaboy
Alzaboy
😀 I've got two ICU,yes I agree problem causing this is not the ICU both work but something is not right, yes ICU works the next day 🤔
5Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 7:43 am
Alzaboy
Alzaboy
moriarti wrote:scratch Hi mate,just to be clear,have you 2 ICUs that you change over  or a large shed full. Smile
ICU feels cold
6Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 7:57 am
Test the Hall Sensors.
7Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 8:00 am
moriarti
moriarti
Laitch wrote:Test the Hall Sensors.
Me too  Smile
8Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 8:10 am
Me too  Smile
Why do you need to be tested?
9Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 8:14 am
Alzaboy
Alzaboy
How does one test hall senser.
10Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 8:54 am
11Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 8:55 am
Point-Seven-five wrote:
Me too  Smile
To see if he's got K-pox yet.
12Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 10:23 am
Me too  Smile
We live in very testing times
13Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 11:22 am
Alzaboy
Alzaboy
Thanks for your help guys
I'll let you know@Dai😀.
14Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 11:22 pm
Alzaboy
Alzaboy
Hall sensor on order, where does it plug into?
15Back to top Go down   ICU overheating? Empty Re: ICU overheating? Tue Jan 18, 2022 11:26 pm
Plug is front right under the tank a flat 5 pin black plastic it's in amongst the nest of wiring fairly close to the ICU.
16Back to top Go down   ICU overheating? Empty Re: ICU overheating? Wed Jan 19, 2022 3:46 am
Rick: AFAIK only the K1200 has a flat five-pin connector. The K100-series are all round five-pin connectors.
17Back to top Go down   ICU overheating? Empty Re: ICU overheating? Wed Jan 19, 2022 10:18 am
Dai wrote:Rick: AFAIK only the K1200 has a flat five-pin connector. The K100-series are all round five-pin connectors.
Yes of course I have been fiddling about on my K1200 and that's how I see it.
18Back to top Go down   ICU overheating? Empty Re: ICU overheating? Thu Jan 20, 2022 8:47 pm
Alzaboy
Alzaboy
Test ride today to see if I still have the k- pox
19Back to top Go down   ICU overheating? Empty Re: ICU overheating? Fri Jan 28, 2022 9:58 pm
Alzaboy
Alzaboy
Hall sensor fixed the issue
Thanks for your help guys 👍
20Back to top Go down   ICU overheating? Empty Re: ICU overheating? Sat Jan 29, 2022 1:52 am
:BW:
