1 Help with starter issue Tue Mar 08, 2022 12:32 pm
VivereCommune
You got Hi Folks,
Recently joined but this forum has been a wealth of great information so far.
I’ve got a 1990 K100 RS that was in a bit of a sorry state so a good donor for a little customisation.
So far I’ve sorted the brakes and removed the ABS, but not yet the electrics related. However once I had done these works I looked to charge up and start her for first time in a month.
So the problem. The starter motor doesn’t initialise, or energise as it was. Previously when you turned the key prior to pressing the started your hear the pump for a second or two. Now nothing.
I’ve directly powered the fuel pump from the battery and it runs, so I’m assuming all ok there. I read that the connector could cause issues so I measured the voltage from the green/white and the brown connector pins and got nothing. So I measured from the battery side of the two wires (snipped the cables) before the connector and still nothing.
Pointers for next steps greatly appreciated.
Oh I’m not massively knowledgeable on the pins layout/numbers etc so and handy tips well received.
Thanks folks.
Thanks folks.
