1Back to top Go down   Starter and load shed relay Empty Starter and load shed relay Sat Mar 28, 2009 7:37 pm
As it is very difficult for most people to follow the full electrical schematic, I made this simpler one about the starter relay and load shed relay.
The function of the load shed relay is to disable lights and accessories to give the maximum power from the battery to the starter.
This may help you to understand how it works as well as troubleshooting a starter not turning.
The way that the load shed relay works is confusing but in fact cleaver.
The relay coil is fed with the positive(+) from the ignition switch on one side and from the ground(-) coming from the starter on the other side(the ground is passing through the inductor of the starter motor). when you push on the starter button, this ground will be switched to positive and the load shed relay coil will then be fed by a positive(+) on both sides (This is like not having power). At this point, the load shed relay will be released and the lights and accessories will go off.
Note: if the gear box is in neutral, the starter button is fed from the digital gear display(power passing through a diode). If not, it is fed by the clutch switch.
THIS IS WHY PEOPLE ARE TALKING ABOUT THE GROUND COMING FROM THE STARTER. If you have a bad starter, your lights, flasher,horn and fan may not be working as the load shed relay coil doesnt get its negative. Smile
Note: When the battery is low, DO NOT TRY TO START THE BIKE. You may end up burning the starter relay (a $130 mistake)
Starter and load shed relay Starte12
2Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Wed Mar 04, 2015 8:07 pm
MikeisonTV
MikeisonTV
Thank for this. So I understand a little more about troubleshooting these relays....will the starter attempt to fire the bike, if the relay is faulty? Or not engage at all?
If the load shed relay is faulty, will the bike turn the starter, but not fire the bike?
Thoughts on testing the integrity of them? will using a test light and the battery work or damage it?
3Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Wed Mar 04, 2015 10:06 pm
Thanks for posting the diagram, Bert.  Now I finally understand what is going on with the load shed relay.  Didn't realize that it is energized closed to power the circuits it controls and goes normally open when the starter is energized.
One question, though.  Is there supposed to be a ground drawn on the other side of the starter relay coil?
4Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Thu Mar 05, 2015 7:22 am
Point Seven Five,
No, the other side of the starter relay coil does not go to ground directly. Bert has exercised artistic license in his drawing and eliminated huge sections of the bike's electrical system for simplicity's sake, including the ICU and ECU. The other side of the coil goes to the ICU. Below 700RPM, the starter coil gets its ground connection through the ICU. Above 700, the ICU prevents the starter relay from engaging for safety.
5Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Thu Mar 05, 2015 9:21 am
Cool, info burned to whatever memory I have left.  Still, it would be handy to show the ECU contact with a note about the 700rpm logic.
6Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Thu Mar 05, 2015 10:34 am
Point-Seven-five wrote:Cool, info burned to whatever memory I have left.  Still, it would be handy to show the ECU contact with a note about the 700rpm logic.
Due to average age of K riders certain aspects are committed to memory to force us to remember.......that 700rpm or 710rpm is important.....
7Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Thu Mar 05, 2015 6:31 pm
kioolt
kioolt
MikeisonTV wrote:Thank for this. So I understand a little more about troubleshooting these relays....will the starter attempt to fire the bike, if the relay is faulty? Or not engage at all?
It may or it may not.  It depends on what is wrong with it.
The starter and the bike will fire fine even if you have a bad load shed relay.  The load shed relay has NOTHING to do with the bike starting or running.  It's there to turn off accessories when starting the bike.
I would test them while completely installed with a voltmeter on the output side of the contact.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
8Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Thu Mar 05, 2015 7:41 pm
"Due to average age of K riders certain aspects are committed to memory to force us to remember.......that 700rpm or 710rpm is important....."
To be precise 711rpm.....no I don't know and I doubt BMW knows either.
9Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Fri Mar 06, 2015 3:46 am
MikeisonTV
MikeisonTV
Thanks k100LT
nigel6527
nigel6527
Hi All,
I was wondering if any one has experienced this. I have stripped down my K1100lt which is currently a cafe racer fitted with a Acewell clock and a bep 3.0. The bike ran fine last year and I also fitted a Motogadget M-lock which operated as it should. Now this winter the bike has been pulled apart and the frame and engine painted. I have stripped out all the ABS loom as it is no longer present on the bike.
So the frame has gone on to the engine fixed at the front mounting points only, I have put the loom back in, connected the clocks and all the other wires and check all my earths which are the main harness earth, Acewell clock water sender earth, motogadget earth these all go to the frame earth point and an earth from the mototronic unit which goes to the gearbox at the moment. . Now, when I activate the m-lock all I am getting on the clock is a red oil light! no horn indicators nothing, no start button.
I then pulled the loom again went and traced all the wiring to check if I has snipped a wire by mistake and all seems to be ok apart from 2 wires. Blue brown wire coming from the frame to Engine plug, this is not connected to anything and I believe it went to an ABS plug. Then I also have a white/brown wire from the main instrument plug which is the 4L warning light wire. This is also not connected to anything. Neither of these I think will cause the issue I am having.
I would point out that I have had the clocks work once then they turned off again. The engine currently has no fluids in it as I am basically trying to test the electrics.
Can anyone shed any light have I missed anything here? I have power on the positive and neutral terminals on the starter relay also. Any help would be greatly received. Thank you. NIGEL
11Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Fri Dec 17, 2021 9:18 pm
davemadsen
davemadsen
I have symptoms that seem to indicate a issue with the load shed relay - as well as symptoms that are NOT consistent with a bad load shed relay.
Recent history: the bike ran fine and as part of maintenance I replaced the voltage rectifier since the brushes were out of spec. I installed the new voltage rectifier and the bike starts fine and the voltage across the battery terminals indicate the bike is charging (13.8v).
Problem: in completing this work I have lost lights, turn indicators, horn, hazard lights, and temperature gauge - classic load shed relay activity. BUT, these items do NOT work before the bike is started. Normally, when the ignition is turned to the ON position, these accessories work until the starter button is pressed at which time the load shed relay shunts the power to these items. The bike runs fine. In summary, the lights, turn indicators horn, hazard lights, and temperature gauge should work with the ignition ON and prior to the starter button pressed - but they don’t.
The fuses are good.
I am perplexed inasmuch as everything worked fine until I removed the ECU, battery and voltage rectifier. Note, I did not remove the alternator to complete this work.
What am I missing?
Dave
Dave
12Back to top Go down   Starter and load shed relay Empty Relay Fri Dec 17, 2021 9:41 pm
daveyson
daveyson
Try swapping the load shed relay with the horn relay.
Your symptoms are consistent with a permanently open load shed relay. When you turn the key on,  you should hear a click from the load shed relay.
 ~120,000 km
13Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Fri Dec 17, 2021 9:54 pm
davemadsen wrote:What am I missing?
You're missing the opportunity to smack the load shed relay with a screwdriver handle, unless you didn't want to admit trying that. Smile
14Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Fri Dec 17, 2021 10:29 pm
davemadsen
davemadsen
Problem resolved. I whacked (technical term) the load shed relay with no satisfaction so I whacked the horn relay and the lights came back on - Eureka!
Is this a one-off incident do I need to plan on replacing the relay? Also, I noticed the load shed relay has a fifth pin. So while it was recommended to swap the horn relay (4-pin) with the load shed relay (5-pin), are they in fact interchangeable?
The pins and sockets of all relays appear corrosion free and still coated with the dielectric grease I applied during previous maintenance sessions.
Dave
15Back to top Go down   Starter and load shed relay Empty Relay Fri Dec 17, 2021 10:35 pm
daveyson
daveyson
The five pin relay is the fuel relay. There are quite a few drawings which label the relays wrong.
Top left is fuel relay, top middle is load shed relay, top right is horn relay. You can think of the horn relay as a spare for the load shed relay, but then horn won't work if it's failed.
 ~120,000 km
16Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Fri Dec 17, 2021 11:25 pm
davemadsen
davemadsen
Ahhh, the Clymer’s manual has the relays mislabeled. I see now I had whacked the load shed relay.
Thanks you so much for following up and providing the clarification.
Dave
17Back to top Go down   Starter and load shed relay Empty Relays Fri Dec 17, 2021 11:37 pm
daveyson
daveyson
No worries. Another quick way to verify it, for example, remove the top right relay (horn relay) then the horn won't work. Remove the fuel relay, then the fuel pump won't work, etc.
 ~120,000 km
18Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Sat Dec 18, 2021 12:19 pm
davemadsen wrote:Is this a one-off incident do I need to plan on replacing the relay?
You'll probably be motivated to replace it after the second or third time you've smacked it. Smile
19Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay Sat Dec 18, 2021 8:04 pm
BEFORE YOU GO OUT AND BUY NEW RELAYS: the ones on the K-series are DIN-A standard which means they have the switched power (pin 30) and coil power (pin 86) swapped over compared to the later (and off-the-shelf) DIN-B series. Secondly, despite having five pins, the five-pin relays are not changeover relays. See this:
https://www.k100-forum.com/t15966-relays-relays-relays-types-and-substitution
