ffbikersa
ffbikersa
Hello!
Need the 03/1993 K1100RS ABS Control Unit
BMW OEM Part No 3452 1459924
BMW 1 459 924 E9088.B
FAG AB2.05
Hella 5SD 005 583-1
WTB: 03/1993 K1100RS ABS Control Unit Bmw_3410
If it is faulty send it to Tosi in Japan He has done several for me and all are still working.
http://bmwk10075abs1fix.web.fc2.com/
ffbikersa
ffbikersa
RicK G wrote:If it is faulty send it to Tosi in Japan He has done several for me and all are still working.
Thanks, good advice!
mw074
mw074
I have a good used unit that I will let go fairly cheap but I have no idea what the shipping costs would be to Sarajevo. I am in the USA.
WTB: 03/1993 K1100RS ABS Control Unit Img_0111
WTB: 03/1993 K1100RS ABS Control Unit Img_0110
5Back to top Go down   WTB: 03/1993 K1100RS ABS Control Unit Empty USPS Wed May 11, 2022 2:32 am
ffbikersa
ffbikersa
mw074 wrote:I have a good used unit that I will let go fairly cheap but I have no idea what the shipping costs would be to Sarajevo. I am in the USA.
Hello and thanks!
I had a look at USPS, it looks this service would be the best choice: https://www.usps.com/international/first-class-package-international-service.htm
"First-Class Package International Service
Affordable Shipping for Packages Under 4 lbs
First-Class Package International Service® (FCPIS®) is a popular way to:
Send packages up to 4 lbs (64 oz), valued at up to $400, worldwide. (Destination countries may have other restrictions.)
Retail prices start at $14.85."
"Weight, Size, & Shape Requirements
Maximum weight is 4 lbs (64 oz).
Packages (Other Than Rolls):
Length (the longest dimension): minimum, 6 inches; maximum, 24 inches.
Height: minimum, 4 inches.
Combined Length, Height, and Depth (thickness): maximum 36 inches.
The postage, address, customs form, and any other required elements must be on a side that’s at least 6 inches long x 4 inches high."
Bosnia-Herzegovina: https://pe.usps.com/text/imm/ab_027.htm
Price list: https://pe.usps.com/text/dmm300/Notice123.htm#_c341
I guess the weight would be between 9 and 32 oz., so small package shipping should cost 30 US$:
WTB: 03/1993 K1100RS ABS Control Unit Screen21
WTB: 03/1993 K1100RS ABS Control Unit Screen22
mw074
mw074
PM sent.
davidneth
davidneth
ffbikersa wrote:Hello!
FAG AB2.05
Hella 5SD 005 583-1
Did you get the ABS computer you needed? I have one, but have cross referenced the numbers you gave.
ffbikersa
ffbikersa
FAG AB2.05
Hella 5SD 005 583-1
Yes I did, and a friend also repaired the one that broke. Thanks
