1 clutch arm 10mm shaft length Tue Jan 04, 2022 9:59 pm
attitude
In the process of replacing slipping clutch on my 1996 K1100LT. The clutch actuating arm rides on a 10 mm shaft. This shaft has the retaining clips on each end. The issue is that this shaft is 30mm longer than it needs to be.
When I worked on my 1992 K75 a few years ago the 10mm shaft did not have this excess length and the washer with retaining clip was tight up on each side of clutch arm and transmission castings.
Looked up part number on realoem and it appears to be the same 10mm shaft on all the K75, K100, K1100.
Anyone solved this and have a part number for the shorter 10mm shaft?
And what is the best way to avoid loosing those little #### snap rings, they fly off when released.
thanks,
Jerome up in Portland
thanks,
