1Back to top Go down   Engine doesn't turn over Empty Engine doesn't turn over Sun May 23, 2021 4:26 pm
Gergely
Gergely
I am struggling for 3 month with no solution. After 3 weeks sitting the bike does not started. Starter motor was (is) not able to turn so not turns over the engine.  After changing battery starter relay and 2 starter motors, no improvements. Now I am trying only with direct cable to starter motor from auxiliary 100% charged battery and starter motor spins maximum only for 1 second (like half rotation of the engine) and stops. Turns over only with sparks out. I dismantled engine completely and checked moving parts, pistons - moving free and easily, camshafts are OK, I cleaned valves and all the internal parts of the engine ò long job. No difference. The only thing is that it is very hard to turn the rear wheel by hand in 5th gear (and almost impossible in lower gears). So even bump start fails.  Someone with same symptoms?  thanx  Greg
K75 1991
2Back to top Go down   Engine doesn't turn over Empty No go Mon May 24, 2021 10:58 am
daveyson
daveyson
The engine might crank with the gear box removed.
 ~120,000 km
3Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Mon May 24, 2021 12:08 pm
moriarti
moriarti
#2 MY way of thinking too and clutch is worth a look at
4Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Thu Dec 16, 2021 5:05 pm
Gergely
Gergely
daveyson wrote:The engine might crank with the gear box removed.
Unfortunately doesn't. Even with gearbox and water/oil pump removed, it is really hard to turn over if sparks are in (starter motor can not do it).
No visible damages can be seen inside. Timing chain is in correct position.
K75 1991
5Back to top Go down   Engine doesn't turn over Empty Engine won't crank Thu Dec 16, 2021 5:59 pm
daveyson
daveyson
I think you're saying the engine will only crank half a turn of the crankshaft. Check if the engine cranks with the clutch removed, as Moriarty points out, especially if you hear a clunk from the clutch when it comes to a stop.
Last edited by daveyson on Sat Dec 18, 2021 3:26 pm; edited 1 time in total (Reason for editing : Deleted mistaken sentence.)
 ~120,000 km
6Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Thu Dec 16, 2021 10:11 pm
Check the bearing caps on the mains and big ends if even one is backwards then its a fairly good chance the engine wont spin.
7Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Fri Dec 17, 2021 2:00 am
disconnect the alternator , could it be that the cup and flange have come together and parts are messed up in the cup area of the alternator ?
just a thought
8Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Sat Dec 18, 2021 1:32 pm
Gergely
Gergely
charlie99 wrote:disconnect the alternator , could it be that the cup and flange have come together and parts are messed up in the cup area of the alternator ?
just a thought
Thanx for the idea, but same issue experienced with alternator out of place.
K75 1991
9Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Sat Dec 18, 2021 1:35 pm
Gergely
Gergely
RicK G wrote:Check the bearing caps on the mains and big ends if even one is backwards then its a fairly good chance the engine wont spin.
Thanx. I will double check. But after reassembly I have the same issue as before, when the engine for sure was original condition.
K75 1991
10Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Sat Dec 18, 2021 1:38 pm
Gergely
Gergely
moriarti wrote:#2 MY way of thinking too and clutch is worth a look at
Thanx. During disassembly, clutch turned to be in very good conditions (even quite clean clutch and connection housing area, still good plate thickness). It works also pretty well.
K75 1991
11Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Sat Dec 18, 2021 2:44 pm
You mention difficulty turning the rear wheel.  Is the clutch properly adjusted?  Can you turn the rear wheel with the clutch pulled in?  I assume you tried to start the engine with the clutch pulled in.
Was the cam chain removed and reinstalled?  Are you absolutely sure the cams are timed properly?  Can you check the valves on the cylinder closest to top dead center?  They should be closed.  An open valve may be preventing the piston from reaching the top of it's stroke.
12Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Sat Dec 18, 2021 3:06 pm
moriarti
moriarti
Hi Greg, OK with the gearbox and clutch removed does  the engine turn over without problem.
13Back to top Go down   Engine doesn't turn over Empty Re: Engine doesn't turn over Sun Dec 19, 2021 4:56 am
I'm thinking about fluidblock, could be from coolant, leaking injectors or the vacuumhose from the FPR.
Engine doesn't turn over Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
