1Back to top Go down   Low Fuel Light Testing Empty Low Fuel Light Testing Sat Oct 30, 2021 10:23 pm
I'm giving one of the K Kronies a hand tomorrow to replace his low fuel globe which is not working. However before we go to the trouble of removing the complete fairing to access the instrument pod I should test the globe. Is there anyway with the infamous 4 pin connector disconnected to activate the low fuel light.
2Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Sat Oct 30, 2021 11:22 pm
No need to remove the fairing to get at the pod. Just the screen and the piece that goes across. Unbolt the mount and pod as one at the dash pad, you need the screen off to get the cable connector off it.
3Back to top Go down   Low Fuel Light Testing Empty Fuel level light Sat Oct 30, 2021 11:24 pm
daveyson
daveyson
With a jumper wire between the earth wire and the low level wire of the 4 pin connector, the light should turn on. If the brick is a later model k100 that would be a jumper wire from the brown wire to the white wire.
 ~120,000 km
4Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Sat Oct 30, 2021 11:30 pm
Thanks on the 75s's it's a pain to get to the instrument pods.  I had to remove mine to fix the speedo needle which for some reason decided to go AWOL. You have to remove the complete fairing and headlight assembly.
5Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Sun Oct 31, 2021 12:15 am
I have used a paint stirring stick to push the float in the tank down to turn on the low fuel light.  You have to hold it there for about 15 seconds, as there is a time delay that prevents the light from blinking when fuel sloshes in the tank.  Same time delay will hold the light "on" when the float is raised.  I cut a notch in the stick that fits over the float arm to help hold it.
6Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Sun Oct 31, 2021 3:06 am
Thanks Gryph but I wanted to eliminate the sender from the picture and just check the globe. I didn't want to pull Bruce's fairing off to find out the globe was fine.
7Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Mon Nov 01, 2021 9:30 pm
We didn't have to remove the pod, the light proved to be functioning. However I was unable to get any readings out of the sender unit. Bruce is now chasing up a second hand one.
8Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Mon Nov 01, 2021 9:48 pm
Check out the page on messing with the fuel sender.  It's possible that the wiper for the low fuel indicator is not touching the metal plate.  Dissecting the sender and bending the wiper might fix the problem.
9Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Mon Nov 01, 2021 10:04 pm
We concluded it might be repairable but he wanted a spare just in case. If we remove it and find it repairable he'll have a spare. If it proves to be beyond repair he won't have to wait for months for a spare from overseas. We tried sourcing one yesterday, the BM Shop Brisbane has a couple but they are for his own projects. He did however offer to connect one to Bruce's bike and confirm the problem was the sender. While there Bruce tried unsuccessfully to pry one out of him. He has left a message for Graham Jones K Bike Beamer parts in NSW, and awaiting an answer. Motorworks UK will be the next port of call. K bike parts seem to be drying up in OZ.
10Back to top Go down   Low Fuel Light Testing Empty Low level light Tue Nov 02, 2021 1:39 am
daveyson
daveyson
I could do a swap with a working sender from my spare brick.
I had a trip to the Gold Coast cancelled due to the lockdowwns, which might go ahead next year, but it's a bit iffy at the moment.
 ~120,000 km
11Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Tue Nov 02, 2021 1:51 am
Wow thanks for the generous offer, I rang Bruce and told him and he'll contact you shortly.
12Back to top Go down   Low Fuel Light Testing Empty Re: Low Fuel Light Testing Tue Nov 02, 2021 4:43 am
Bruce Petterson
Bruce Petterson
robmack wrote:Check out the page on messing with the fuel sender.  It's possible that the wiper for the low fuel indicator is not touching the metal plate.  Dissecting the sender and bending the wiper might fix the problem.
Thanks for that.  I might give that a go.
 Regards Bruce
13Back to top Go down   Low Fuel Light Testing Empty Fuel Sender for K Model. Tue Nov 02, 2021 4:54 am
Bruce Petterson
Bruce Petterson
daveyson wrote:I could do a swap with a working sender from my spare brick.
Wow.   Thanks for that, I really appreciate it Daveyson.  I am keen so I will send you a PM with my contact details etc.
Kind regards Bruce
