bmwk100rs
bmwk100rs
The picture below is from the Clymer book (I know it's not the best source of truth) and it recommends to apply sealant to the surface indicated within the black arrows. What about the surface indicated with purple arrows near the coolant passage?  Do you guys apply sealant there? TIA!
Apply sealant to the pump mating surfaces Img_1118
2Back to top Go down   Apply sealant to the pump mating surfaces Empty Sealant Sat Sep 25, 2021 2:02 pm
daveyson
daveyson
When you remove the pump, I think you'll see an O-ring there, in a groove on the engine face. You can see it on the other drawing above it.
 ~120,000 km
bmwk100rs
bmwk100rs
daveyson wrote:When you remove the pump, I think you'll see an O-ring there, in a groove on the engine face. You can see it on the other drawing above it.
Sorry daveyson, but I'm not sure I follow.  Do I also need to put sealant on mating surface highlighted with the purple arrows?
4Back to top Go down   Apply sealant to the pump mating surfaces Empty Sealant Sat Sep 25, 2021 4:05 pm
daveyson
daveyson
No you don't need sealant there, the O - ring will seal the joint there. You can buy one before you start the job and just replace the O - ring, even if it looks good.
It will make a lot more sense after you remove it and can take a look at it.
 ~120,000 km
bmwk100rs
bmwk100rs
daveyson wrote:No you don't need sealant there, the O - ring will seal the joint there.
Gotcha, thanks daveyson for the clarification. I have indeed a brand new O-ring to place there.  Thanks again, cheers!
