1 K100 Radiator Advice Wed Aug 25, 2021 11:39 pm
jjefferies
Background: Finally decided to get off my duff and start working the K100 project I picked up last spring. No idea how many miles on the bike as the seller wasn't exactly straight about any or everything. I got that message when he stated that the only reason he was selling was that he needed to make his bail money. Seems he had fallen off the wagon and waved a pistol around when the new owners of the building where he had been super for years took over. But the bike had sat in excess of 5 maybe 10 years in the 1st floor garage of that apt building in Berkeley Ca and was in a sad state of repair. Before starting the restoration I did get the bike to fire up briefly but did not ride it as that looked a tad dangerous. Tires and brakes were questionable. I took the frame off along with the front wheel and left the engine and rear wheel on a trolley. Had the frame powder coated and have begun reassembly. For some reason known only to the previous owner he had cut 4 wires in the main electrical harness just before it enters the headlight. So I spent an hour or so replacing his jury rigged wiring with my jury rigged (but soldered) wiring and sealed the cable cover as best I could. Now I want to begin reassembly of the frame and engine so I can work on a piece at a time. I figure it will be winter before I get much further and it's best to be able to wheel the machine around a bit. Suspect I'll build a tent around it so it will be out of the weather and accessible. The garage being full of K75's and such.
The problem: I'm ready to start the reassembly but need to get the radiator re-mounted and all the hoses connected up. But the radiator is in sad shape (as was the whole bike) and many of the aluminum fins are damaged, bent back or disconnected. As near as I can tell the radiator doesn't leak. At least not in my cursory testing. But who knows. Any advice or comments about reworking a K100 radiator. Is there any reason not to? I've been trolling the net looking for 2nd hand radiators but so far haven't found any.
All polite comments and advice appreciated.
