1 New fuel pump not working ? Sun Jul 25, 2021 12:44 am
Spexbike
[ltr]I am going crazyyyyyyy ! The bike ran about a week ago when I still had overheating problems.I got a new coolant sensor, a used cooling relay,removed the vacuum sensor and plugged the barb on cyl 1 on the throttle body.Bike won't start.No fuel getting to the fuel rail.open the tank ,took the fuel hose that goes to the top of the pump off the filter,pushed start... at this time I should have fuel squirting out of the hose,correct? but nothing.It's a new pump,it worked before,checked the fuse which seemed good,replaced it just to make sure.Even put the old cooling relay back in to make sure that is not the issue,but that shouldn't even have anything to do with the fuel pump,right? SOS ![/ltr]
[ltr] [/ltr]
[ltr] [/ltr]
