1Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Fuel Pump Brushes (SOLVED) Wed Dec 01, 2010 2:37 pm
club_c
club_c
My new project, the RT, had a seized fuel pump which I succcessfully revived using info posted on this site. However, when gently knocking the unit back into the casing, I broke both armature brushes. Anyone know of a replacement for the brushes?
2Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Thu Dec 02, 2010 2:20 pm
No answers...
Here's what I would do (based on not having seen the said brushes).
Are the leads on the brushes soldered on? Can you desolder the brushes and take them to a parts-supply shop and see if they have something close to the size you need?
Then it may be possible to get a Dremel type tool to grind them down to size and resolder them?
I haven't seen anywhere that you can get the brushes by themselves (I gather that you already know this...).
That's my suggestion.
3Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Thu Dec 02, 2010 5:46 pm
An 'Oh, shit' moment for sure. I've had one or two of those. Good luck sorting it, and please let us know if you have any luck sourcing some.
4Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Thu Dec 02, 2010 5:49 pm
club_c
club_c
Oh, I'll beat this. Just annoying is all. The one thing I've found on these bikes is they are repairable/serviceable to a great degree, and this forum gives excellent support.
5Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Tue Dec 07, 2010 3:01 pm
club_c
club_c
Sourced a couple of starter brushes for a Harley, RCP brand, number H12. Needed just a little filing to fit into the brush holders. The pump spins up nicely now, and hopefully will generate pressure once its re-installed.
NOTE: Those brushes will file down very quickly given their soft composition.
6Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Wed Dec 08, 2010 12:18 pm
Stout
Yes they do.
They also won't put up with being clamped in a vice so you can file them Embarassed Found that one out the hard way the first time I tried to adapt some generic brushes purchased from an auto electrican for the starter of my GSX1100. Had to turn straight around and drive the 20km back to town to buy another brush....
7Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Wed Dec 08, 2010 3:35 pm
Ned
Ned
just a suggestion... can we have an area for "solved" bits that are deemed important for us all, but don't quiet make the "tutorial" format or category.
Ned
8Back to top Go down   Fuel Pump Brushes (SOLVED) Empty Re: Fuel Pump Brushes (SOLVED) Tue Jan 04, 2011 9:54 am
Ned wrote:just a suggestion... can we have an area for "solved" bits that are deemed important for us all, but don't quiet make the "tutorial" format or category.
good idea ned
