1Back to top Go down   K100 From El Paso Texas! Empty K100 From El Paso Texas! Mon Jun 28, 2021 9:14 pm
Ecarranza
Ecarranza
Hello All,
I’m from El Paso Texas. Working on fixing up my 1985 K100 I just bought.
Bike was running fine when I bought it. It was sitting for some time.
I left it out in the cold one day and now it won’t start.
If I remember correctly the fuel pump would turn on or make a noise when I turned the key ignition to on.
When I press the starter button it does make noise and turn on just that the bike won’t turn on.
I checked the fuses and everything is good, I bought a new Fuel Injection Relay and a new fuel pump and still same issue.
Any help would be appreciated.
Thank you
2Back to top Go down   K100 From El Paso Texas! Empty Re: K100 From El Paso Texas! Tue Jun 29, 2021 1:51 am
Welcome Ecarranza Smile
K100 From El Paso Texas! Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   K100 From El Paso Texas! Empty Re: K100 From El Paso Texas! Fri Jul 02, 2021 9:01 pm
Ecarranza
Ecarranza
K100 From El Paso Texas! 3a874910
4Back to top Go down   K100 From El Paso Texas! Empty Re: K100 From El Paso Texas! Fri Jul 02, 2021 9:03 pm
Ecarranza
Ecarranza
K100 From El Paso Texas! 0c408210
5Back to top Go down   K100 From El Paso Texas! Empty Re: K100 From El Paso Texas! Fri Jul 02, 2021 9:04 pm
Ecarranza
Ecarranza
K100 From El Paso Texas! 9a179710
How I bought the bike and how it is now, work in progress
6Back to top Go down   K100 From El Paso Texas! Empty No go Fri Jul 02, 2021 9:12 pm
daveyson
daveyson
Are you getting fuel, are you getting spark? Is a good place to start.
A few days ago I resisted the urge to suggest checking that the muffler isn't stuffed with Cuban cigars.
 ~120,000 km
7Back to top Go down   K100 From El Paso Texas! Empty Re: K100 From El Paso Texas! Fri Jul 02, 2021 9:30 pm
Ecarranza
Ecarranza
Yea I am getting fuel and spark I already checked that.
Not sure what to check next
8Back to top Go down   K100 From El Paso Texas! Empty No go Fri Jul 02, 2021 9:39 pm
daveyson
daveyson
Maybe too much fuel, then you might smell it or see fuel dripping out in front of the muffler, then unplugging the pump electrical plug might let it run for a short moment.
Maybe air leaks, then it would be too lean.
What other things have you eliminated?
Maybe give it a service, that often reveals the problem.
 ~120,000 km
