Number of posts : 7967
Brind wrote:Thanks guys.
The original coil was burnt at the bottom so I assumed that was the problem. Changed the coil but still no spark. Have tried two other coils and still no spark. There is power to both coils. Trigger unit (HES) visually appears ok. I’ll check the connector under the tank.
Reluctant to change either the trigger unit or the ignition control unit until I can identify the cause of the fault.
That may have been caused by bad plug leads. Plug leads are high on the potential list. If you have original plug leads have your spark plugs got their bobbins on if you have NGK plugs?
1971 Yamaha 125 YAS-1
