1Back to top Go down   Battery -- Odd Issue Empty Battery -- Odd Issue Tue Jun 15, 2021 3:47 am
Shep
Shep
Brand new battery (AJC ATX20L) from a Canadian Supplier called Battery Clerk.
Battery is 12 V, 18 Ah, CCA 270 A, AGM technology.
Installed in bike 1987 K100 RS, with no ABS and no alarm on bike. Charge topped up with NOCO charger.
Over three days 12.8 V drops to 12.3 V then on day four it is sitting at 10.5 volts! Used a Fluke meter to verify  the reading. Only load on battery would be the BMW digital clock and a digital Voltmeter readout plugged in to the 12 V outlet under the seat.
What am I missing?
Shep
2Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 3:51 am
BobT
BobT
Battery is a duff one. It should hold its charge for weeks. There is nothing on a stationary bike that would draw enough current to drain a battery like that. Even having ABS would make no difference.
3Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 7:14 am
What Bob says. It's screwed.
4Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 8:10 am
Take it out of the bike and put a full 12.8v charge on it. Let it sit for a day and check the voltage. Then take it back to the dealer for a load test. That should tell the dealer if the battery is indeed toast.
5Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 8:21 am
yamaguzzi
yamaguzzi
When fully charged  if you remove a terminal does it still drop in voltage while in the bike ? If so the battery is toast if not the problem is in the bike
6Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 8:27 am
BobT
BobT
Point-Seven-five wrote:Take it out of the bike and put a full 12.8v charge on it.  Let it sit for a day and check the voltage.  Then take it back to the dealer for a load test.  That should tell the dealer if the battery is indeed toast.
Why? If you run the bike then it will put 14v or so into the battery and do the same.
7Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 1:21 pm
The idea is to see if there is an internal short vs a parasitic load on the the bike that is pulling the battery down. Follow that with a load test at the battery store, and you have an excellent argument for a replacement battery.
8Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 9:10 pm
No chance you fitted a permanently live USB outlet......?
9Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Tue Jun 15, 2021 9:15 pm
BobT wrote:Battery is a duff one. It should hold its charge for weeks. There is nothing on a stationary bike that would draw enough current to drain a battery like that. Even having ABS would make no difference.
Having ABS can make a difference both my K1100 and my wife's K75 had faulty ABS and it was caused by leaky transistors and it was discharging the battery in about 5 days. If all is well then ABS or not there should not be a difference but most of these bikes are around 30 years and these type of electrical problems tend to surface after about 20 years.
10Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Wed Jun 16, 2021 3:45 am
BobT
BobT
Are you saying that the ABS is drawing power when the ignition is switched off? Sounds like something is wrong there.
11Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Wed Jun 16, 2021 7:06 am
BobT wrote:Are you saying that the ABS is drawing power when the ignition is switched off? Sounds like something is wrong there.
YES Bob that is what I am saying the ABS unit has switched and unswitched power so a leaky transistor can and will cause the battery to discharge.
12Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Wed Jun 16, 2021 8:18 am
Ummm... The OP's bike doesn't have ABS.
13Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Wed Jun 16, 2021 8:34 am
Point-Seven-five wrote:Ummm... The OP's bike doesn't have ABS.
Yes I realize that but I was responding to what Bob had said earlier. "Even having ABS would make no difference."
14Back to top Go down   Battery -- Odd Issue Empty Re: Battery -- Odd Issue Wed Jun 16, 2021 2:27 pm
gorio
A quick check by sticking a amp meter between the battery positive post and the positive cable/cables running to the bike will tell you if there is leakage with the key off. If there is you can then check fuse by fuse to isolate the circuit that has an issue.
Or at least that is what I do.
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
1982 Kawasaki 750GPZ
1975 Norton 850 Commando
