1Back to top Go down   BEP to K100 1985 Empty BEP to K100 1985 Mon Dec 06, 2021 7:10 pm
pwfree
pwfree
Hi everyone,
I am not too experience with this forum stuff so I hope that I have. Ot missed something. I have a 1985 k100 that I am converting to a cafe. Everything works great with the lunchbox but i am trying g to install a motoscope Pro and using the BEP 3.0.
I hope this isn't too dumb but i u understand the basic hook up of the motoscope to the BEP, fused red to bat, brown to switch, yellow to rpm, white to speed, blck to ground and i understand that i need to use the included speed sensor. What i am unclear on is how to connect oil temp. Gas level etc.  Do these get hooked from the sensor directly to the BEP 3.0 or do I connect them to a break outbox that is connected to the motoscope orange wire?
Am I even close!???
Tha is for your patience and help!
Gave your question it's own topic.
Arlina Smile
2Back to top Go down   BEP to K100 1985 Empty BEP to K100 1985 Mon Dec 06, 2021 9:29 pm
pwfree wrote:.... What i am unclear on is how to connect oil temp. Gas level etc.  Do these get hooked from the sensor directly to the BEP 3.0 or do I connect them to a break outbox that is connected to the motoscope orange wire?
Am I even close!???
Not even close.  There is no oil temp sensor available to your Motoscope.  You have to install a new aftermarket sensor in the oil pan drain plug and run that to the Motoscope.
You can't use the fuel level indicator on the '85 K100. It's incompatible with the Motoscope. No aftermarket alternative unfortunately.
Similar topics
» 1985 K100
» 1985 K100
» 1985 K100
» My 1985 K100 RT
» 1985 K100
