1Back to top Go down   Replacement Key Empty Replacement Key Wed Feb 10, 2021 4:51 pm
moriarti
moriarti
BMWNA told me to contact one of the main dealerships. This i have done only to find that this service is only available to USA Reg bikes, so much for the special relationship then Crying or Very sad Anyone with  idea2 on how or where i might try next Chatter
:BW: :BW: Thanks in advance
2Back to top Go down   Replacement Key Empty Re: Replacement Key Wed Feb 10, 2021 5:01 pm
Replacement Key Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   Replacement Key Empty Re: Replacement Key Wed Feb 10, 2021 5:06 pm
moriarti
moriarti
Sorry Arlina i should have said ,a pre-cut key to original code  Embarassed
4Back to top Go down   Replacement Key Empty Re: Replacement Key Wed Feb 10, 2021 5:10 pm
Bugger....
Contact the factory, scroll to bottom;
https://www.bmw-motorrad.com/en/home.html#/section-mybmwmotorrad
5Back to top Go down   Replacement Key Empty Re: Replacement Key Wed Feb 10, 2021 6:21 pm
moriarti
moriarti
6Back to top Go down   Replacement Key Empty Re: Replacement Key Wed Feb 10, 2021 7:38 pm
Take the whole bike or just the ignition switch to a competent locksmith and they will make a key to suit. AFAIK folding key blanks are available fron Motobins.
7Back to top Go down   Replacement Key Empty Re: Replacement Key Wed Feb 10, 2021 8:34 pm
I've just ordered a folding key from Motobins 8.50 UK pounds Motorworks 15.17 UK pounds plus freight.
8Back to top Go down   Replacement Key Empty Re: Replacement Key Thu Feb 11, 2021 1:38 am
I've had a heck of a time getting a BMW key blank cut. I got one cut a few years ago, but when I went back I told the owner that they had cut a key for me previously he got angry and said that his helper should not have cut the key because it would ruin the machine's $300 cutter.
Turns out locksmiths are only set up to cut brass blanks, and the hardened steel BMW blanks require a special carbide cutter that is only used on safe deposit box keys and a few others. According to the locksmiths I talked to in my search, even those keys aren't as hard as the steel in the BMW blanks.
Fortunately, if you have a key to copy and a lot of time, you can file the profile into the blank with a good toolmaker's file. If you can get the blade of the folding key out of the handle, it may be possible to anneal it to make the filing process a bit easier.
9Back to top Go down   Replacement Key Empty replacement key Fri Apr 30, 2021 12:35 pm
moriarti
moriarti
YES YES ,I have my key, ROSS of ALAN JEFFERIES BMW has spent months pursuing BMW UK/GERMANY and despite all obstacle's has succeeded. So a big shout for him ,not a big order for the shop but shows CUSTOMER SERVISE still matters  cheers cheers
10Back to top Go down   Replacement Key Empty Re: Replacement Key Fri Apr 30, 2021 2:52 pm
Bonzo
Bonzo
moriarti wrote:YES YES ,I have my key, ROSS of ALAN JEFFERIES BMW has spent months pursuing BMW UK/GERMANY and despite all obstacle's has succeeded. So a big shout for him ,not a big order for the shop but shows CUSTOMER SERVISE still matters  cheers cheers
Good result mate  bounce
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
11Back to top Go down   Replacement Key Empty Re: Replacement Key Fri Apr 30, 2021 4:05 pm
