1 Rubber Gasket Ring failure Mon Sep 12, 2022 11:00 pm
redrockmania
The early version of the K100 ( to 04/1985 ) has the problematic round 4 pin wiring connector going into the tank to the fuel gauge and fuel pump. I'm in the process of fitting an improved plug connector. The connector is bolted into the left front underside of the tank using a large diameter plastic threaded nut. I found that when I undid the nut, the sealing rubber washer (Part #: 61 31 1 459 448 described as a "gasket ring") had turned into a soft gooey mess. The dimensions of the washer are 27.5mm OD; 21mm ID, 2.4mm thick. BMW replacements of this part are inexpensive, but, I would like the peace of mind of a better rubber compound - fuel leaks can lead to fire. I've purchased several 100mm x 100mm 3mm thick Viton (FKM) sheeting to make my own with.
