1 K100LT electrical fault Tue Apr 15, 2008 2:20 pm
barnesst
Hi, I've just come across these forums while looking for some info.
I have a K100rt which wont turn over on the starter and wonder if anyone can help? Here are the complete symptoms:
With ignition in parking lights position, parking lights are on.
With ignition in normal "run" position, all the dash lights come on as
normal, but there are no headlights / tail light, the indicators only
work while you hold the button pressed in, the horn doesn't function
and the starter won't turn over. (when the starter button is pressed,
the relay clicks and the fuel pump runs but no starter motor).
The bike can be bump started, but if it is, the lights, horn and indicators still don't work.
So the question is, what can affect all of the above components at the
same time? I was coming back from Wales, and all was fine until I
stopped the bike only to find the above faults.
