Saints
Saints
Hello!
So the bike is K1100RS 1996 and it has roughly 130 000km on it. This is my first bike and i have basically no experience with motors, in any vehicle. But i think i am doing OK, this forum and others have been a gold mine for knowledge. I will take it to the shop only as last resort.. trying to learn how to take care of it myself. It was running last summer and a lot has been renewed during winter days. After all the parts I found out to be defective and replaced, I would have assumed that it runs better, not other way around..
Against all odds it started after the rebuild. It is running rough on idle, not very good, have a look at the video.  In both videos it is running quite cold, less than 5 minutes.
It has..
-new throttle body rubber boots (old ones had cracks)
-used but good throttle body to airbox rubbers (old had cracks)
-throttlebody butterflies synched with the water method.. so that same amount of water flows through
-new air filter
-new fuel filter
-outside of the tank all fuel lines new
-new injectors EV14
-new NGK 5ohm leads and DR7EA sparkplugs
-valves clearances adjusted.. 10 new cam followers.. (sadly after adjusting one is still out of range. it would have needed 2.45mm cup, but only 2,50mm was available)
-new crankcase breather hose
-new hose that connect on back to all four throttlebodies
So basically everything that is connected to air intake is renewed, so not likely to have leaks there (didn´'t check with gas...yet..)
And gasoline distribution should be in order, at least it was running last summer and now there are renewed lines and new injectors.
When i removed the exhaust, 1&4 were black on the inside, as one would assume.. but the 2&3 were white. Then proceeded to see if the plugs were different colour, but they were all so black and covered in oil that i could not tell. But leads were in awful shape, very corroded, previous owner had put NGK plugs without those hats, so it had arched quite much.
After it didn't run so well, i took the spark plugs out to see if the gaps are okay, they were all between 0,6-0,7mm. But the colour was different, once again 1&4 were more black, and 2&3 white. Considering that it had been running max 20 min, quite noticable differences. Then put it back together and sprayed water to exhaust pipes, to see if pipes are hot evenly. But 1&2 are noticeable colder than 2&3.
Is the most likely defective part causing bad ignition in 1 and 4 cylinders 1&4 ignition coil? Connectors that connect to ignition coils both give 12V on one of the connectors. Am I on right track here? scratch Or can there be problem with mototronic?
Second problem is that ticking sound.. i have read that i could be caused by bad timing chain tensioner, but the sound seems to be coming more from the back side of the motor. Another is that the injectors are ticking.. but not sure about that.. what are the expert opinions on the ticking sound? The slightly tight valve is cylinder 4 exhaust, it should be 0.25-0,30 but 0,25 does not go between.. only 0,20.. if it is so tight that tills.de does not even sell cam follower that thin, what is the next thing that must be changed to fix that gap?
Trying to gather all the needed parts in one order.. but as i have experienced, that rarely is the case   study
Best Regards
Saints
Bricklayer
Bricklayer
Wild guess since a pair of spark plugs were black... remove cover over plugs and turn off the lights, the sound almost sounds like arcing with the high voltage jumping to ground. It's a quick check and eliminates on possibility. There is also a correct way to route the plug wires.
https://anthonymrugacz.net/
Saints
Saints
Greetings.. to the correct way of the cables, didnt put them very nicely back as i thought i will be takin coils apart very soon..
Took shot in the dark, pitch black when engine running, so no arching?
Bricklayer
Bricklayer
With a pair of spark plugs black it sounds like a coil as the fire together. Maybe check the leads  on the primary side. Check the resistance of the coils  on the one labeled 1-4. Specs are available online. It is simple stuff but troubleshooting is a methodical process.
As Bricklayer mentions, it sort of looks like one of the coils is giving you trouble.  Another test you could do would be to swap the coils.  If the problem switches to #2 and #3 you can be pretty sure the coil has a problem.  If the problem doesn't move, the cause may be the Hall Effect Sensor or something in the ignition controls.
Coil resistance specs with ignition off and coils disconnected, from BMW's Motronic 2.1/2.2 Diagnosis Manual:Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Scree247
Saints
Saints
Tried to do resistance measurements but i think my multimeter is busted.. only reading i get is 0L, tested it to few resistors and same outcome. But that is that.
I swapped the coils and the problem persists the same, at least temperature stays the same.. no.1 is the coldest, 2&3 are hot and 4 is hot, but not as hot as 2&3. So would this give pardon to the coils? Hard to picture that problem could be in the leads, they are new and seem to connect very well, nothing is loose and all contact surfaces are clean and great condition. But everything is possible.
Is there a way to test the hall effect sensor?
Sounds like the coils are okay.  Try pulling the #1 spark plug and see if it sparks with a good spark then do the same for #4.  That will confirm that the cylinders are getting spark and the problem is fuel supply.
#1 and #3. Or #2 and #4. #1 and #4 are on the same coil. Or did I miss something obvious?
10Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough and humping Thu May 18, 2023 6:34 am
daveyson
daveyson
So 1 and 4 are colder, so I'd also test the leads or swap them. The high tension circuit's don't return to the battery, for example 1 goes to 4 and then back again, so they depend on each other. If no luck I'd swap 1 and 4 spark plugs with 2 and 3.
 ~120,000 km
11Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty new measurements Thu May 25, 2023 5:12 am
Saints
Saints
Got a new multimeter and measured the coils, both have 0,5 ohms and 12,5 ohms. Also tested with the leads swapped, made no difference.
Interesting was that when we tested for spark (injector plugs disconnected). We removed 1 spark plug at a time, grounded and cranked, we seemed to get even spark on all plugs.
Tested also for compression, 1 plug out at a time. All gave ~11 bar compression at normal throttle position and ~15 bar throttle fully opened. seems quite high (?). Motor temperature was not optimal for compression test, around 50°C
Tested for intake leaks with butane/propyl gas, found no increase in rpm
Then I loaned a timing light and thought that maybe I can check that.. connected the injectors again and put the motor running ~1000rpm and plugged it to:
no. 1 lead: Just occasional flashes..
no. 2 lead: flashing quite good.. kind of... half of the time
no. 3 lead:I would say best flashing
no. 4 lead: Surprisingly good, almost as good as 3.
Not very statistically accurate measuring technique.. video in the drive.. Tested also with higher rpm.. no drastically changes to flashing
Does this timing light test give any real information..
Last edited by Saints on Thu May 25, 2023 6:00 am; edited 1 time in total (Reason for editing : added intake leak test)
12Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Thu May 25, 2023 6:11 am
daveyson
daveyson
Since swapping the leads made no difference, I'd swap the spark plugs. I'm hoping that one or four is bad, and two or three (plug or lead) is half bad. But might as well test the resistance of the leads while at it anyway.
 ~120,000 km
Saints wrote:Tested also for compression, 1 plug out at a time. All gave ~11 bar compression at normal throttle position and ~15 bar throttle fully opened. seems quite high (?).
Usually it's all plugs out to distribute engine cranking force optimally. Closed throttle gives inaccurate readings. Wide open throttle packs the cylinder with air for an accurate reading of compression power. Your engine's compression is classified as good in the BMW service manual that is downloadable from this site. It's full of news you can use. Smile
The timing light is showing that spark is intermittent or of variable quality in cylinders #1 and #2; either condition must be remedied, so the light is useful in that regard, unless the timing light is faulty, too.  Laughing If the light is ok, the cause could be faulty spark plug leads and/or faulty plugs, as daveyson is indicating, unless it's something else. Laughing
I dont see that the leads have bene replaced.
Running HT leads on NGK plugs without the screw on bobbins destroys the inside of the cap on the lead and also is not good for the coil.
The ticking sound you are hearing is to my mind shorting of a coil or HT lead.
If the bike was run for a long time in this condition I would be suspecting both coil 2/3 and the leads for 2/3 as being the problem in which case swapping the coil AND with its plug leads would be necessary to see if it swaps over to cylinder 1/4.
Saints
Saints
In the opening post I listed new things. Bike had bad leads, because of nkg spark plugs being used without hats previously. They had arched a lot from the inside (now that i remember, two leads were especially bad, and two were bad but better, i spared the other pair.)
But now both the spark plugs and leads are NGK and new from tills.de. But i quess not new anymore, they have been used under 1 hour idling in neutral.
Saints wrote:But now both the spark plugs and leads are NGK and new from tills.de. But i quess not new anymore, they have been used under 1 hour idling in neutral.
Exactly. Laughing Maybe it is time to consider this option.
17Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Fri May 26, 2023 8:43 am
daveyson
daveyson
Doh got a bit lazy there. Another thing to try, unplug the tank, swap the black/red wire of the coil with the black/blue wire to see if that shifts the problem.
 ~120,000 km
18Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty back.. Tue Jul 04, 2023 6:49 am
Saints
Saints
Had to wait some shipments.
Now i have spare HES, coils and voltage display. All coils give same 6 ohm readings.
1. Charged battery to full.
2. Cleaned coil earth and signal, HES plug, motronic connections again, installed new coils, no difference.
3. changed HES, no difference.
4. measured leads, all 6 ohms.
5. changed no.1 lead to old lead, with NGK bobbin installed to spark plug. No difference.
6. reversed all the plugs 1<->2 and 3<->4, no difference.
Maintenance break, used engine flush, 10min idle (runs incredibly smooth with 2 cylinders..). Voltage meter shows steady 14V. At the end did waterspray test, 1&4 cold, 2&3 hot. Changed rear drive and gearbox oil.
7. did continuity test to HES wires to motronic plug, orange and brown signal wires good continuity to their pins.
8. tested motronic fault codes (L= long 2,5sec flash, S= short flash) by grounding pin1 for 5 sec.
LLL SS L SS L, break, repeats same to infinity.
ign off, pin ground.
LLL S L S L,  break, repeats same to infinity.
ign off, pin ground.. the same cycle repeats, those two codes. What can i get from these? No four digit codes, or do i just combine them?
idle for some time, same fault codes after that.
9. Doubted fuel supply. Took injectors out with the rail, put 20ml syringe cups to each injector. crancked for about half a minute. Each injector gave same amount of fuel, 1 ml.
10. Battery in charge again.
@daveyson what do you mean by black/red and black/blue wire?
Could i do some multimeter testing with those 2x2 green coil wires? Or with HES wires and motronic plug? Anything else i should check from wiring? what would be the next step?
Thanks..
btw. Does it matter is the HES T-cover in place when running the motor? (beginning to doubt even star positions in the sky could make a difference at this point..)
Last edited by Saints on Tue Jul 04, 2023 6:54 am; edited 1 time in total (Reason for editing : important add)
19Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Tue Jul 04, 2023 7:06 am
daveyson
daveyson
I'll have to read this again later, the wires from the computer to the coils, swap them at the coils to see if it moves the problem was the thought, I think.
 ~120,000 km
Saints wrote:LLL S L S L,  break, repeats same to infinity.
Infinity? Not yet. Laughing
The code is based on short flashes not flash combinations of varying duration.  **  **  **  **  would translate as 2222. Are you reading code flashed by the temperature light in the instrument cluster? The instructions aren't working for you. Crying or Very sad
Follow both daveyson's and Olaf's swapping suggestions.
I had a very similar problem with my K1100LT many years ago. Just about drove me nuts (some might say what would be the difference) and the only thing that got rid of the problem was slightly retarding the TPS, at a guess 2-3 degrees. I gave up trying to figure out why as it made no sense at all but it worked. The idle was slightly high at 1100 RPM.
I have absolutely no idea why it worked and have spent many hours trying to figure it out but I had to accept that it was what it was.
I didn't really like the high idle but over the eight years I rode the bike I tried many times to solve the problem but in the end just accepted it and enjoyed the 120000km I put on it.
I still have no explanation of why the rough idle started or why retarding the TPS worked and put it down to one of life's mysteries.
Saints
Saints
Seems reasonable, i will try swapping the coil wires, they are quite tightly packed.
I have uploaded video of the led flashing, it is temporary led connected to temperature warning in instrument cluster. Does that seem regular fault code flashing to you, Laitch?
Turning the TPS, so Rick G, do you mean counter clockwise or clockwise?
Thanks!
I am dealing with something similar, thought it was cured and also it is using a lot more fuel.
Everything is done just like yours, even new EV14 injectors, vacuum pipes, the lot.
There was a coil issue which was replaced but still not back to where it was.
I wonder could there be a Motronic fault? Have you identified the quality of the spark on 2/3 as against 1/4? Is there a potential earth [not live supply] issue from one of the coils?
Saints wrote:Seems reasonable, i will try swapping the coil wires, they are quite tightly packed.
Thanks!
Looking at the rear turn it clockwise. From memory it was about 1.5mm at the screws.
Saints wrote:Does that seem regular fault code flashing to you, Laitch?!
Which post has the video, Saints? I can't find it so I can't comment on it. The code flashes should be short and all of the same duration.
Saints
Saints
Laitch, in the starting post you can find a link to my drive, video is there.
Tested switching the coil wires - got a loud bang and did not start.. left it with that..
Messed with the TPS, turned it about 1,5mm.. voltage dropped to 0,09. Starts.. runs and humps.. no way to get rpm increased, does not seem to work. Tried different setups.. no good results.. Put it back to 0,375. Back to normal problems..
Saints
Saints
Ps. Where did you find that kind of post made by me?  ” Does that seem regular fault code flashing to you, Laitch?!”
I have not used such yelling Surprised
Added a ”crancking spark test” video also..
Saints wrote: Does that seem regular fault code . . .
1133--No signal from Hall Sensor #2 is what it seems to me, Saints.
If you are reluctant to believe what you have read in this post written by a maven of Brick electronics describing an LED assembly exactly resembling what you have as what is needed, Saint, or according to the procedure described in the troubleshooting guide in the Tech Page here, and can only move forward with confirmation from a random layabout on the other side of the Atlantic, I'm your guy.
Go for it! cheers
Saints
Saints
Hall sensor seems to be working, according to that test.
Tested the spare first.. being what i am, i connected + and - wrong way around to the sensor. Noted my error and put it right, but i quess i fried it? Or the the spare i got is faulty. Because then i tested one on the bike and it worked.
32Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Wed Jul 05, 2023 6:44 am
daveyson
daveyson
I didn't explain myself well so here she goes.
You have swapped many parts to try to shift the problem to cylinders 2 and 3, but no difference so far.
Let's suppose for a minute that the black/blue wire to the coil is crappy, that would explain why the problem hasn't shifted. Swap it with the black/red wire at the coils, but then you also have to swap the high tension leads. That might shift the problem to cylinders 2 and 3.
Down the track, another point is that spark plug 2 is ridiculously clean, enough to make you think, are there bubbles in the coolant, excessive condensation out the exhaust, fuel smell at exhaust, something about the odd spark, or something else?
Another thing, if you would say the ticking matches the missing flashes from the timing light, do this test at night, idle and rev while looking at the HT leads and the coils for any arching. It wants to be dark, I'm talking real dark, darker than a black steer's bumhole on a moonless prairie night.
 ~120,000 km
daveyson
daveyson
Saints wrote: (beginning to doubt even star positions in the sky could make a difference at this point..)
I wouldn't worry about the star positions but don't do it on a full moon, choose a moonless Chinook night.
Actually if the trouble code points to the hall sensors, I spose you should test them. I just test them simply with a 12V LED test light.
 ~120,000 km
Saints
Saints
I tested the hall sensor with led, it is OK.
As stated, bike is -96 model, so i do not have black/blue black/red, all i have is green. And i tested that i switched coil plugs (where the green wires come, other thin and thick green wires) 1/4 <-> 2/3. All i got was a loud bang when starting, left it with that.
35Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Wed Jul 05, 2023 8:09 pm
daveyson
daveyson
What are the colours of the wires from the computer to the coils? ignoring the hall sensor wires at the moment.
Did you remove both the primary and secondary wires from coil one and move them to coil two, and coil two wires to coil one? Or did you just swap the primary wires?
 ~120,000 km
Saints
Saints
Did you move both the primary and secondary wires from coil one and move them to coil two, and coil two wires to coil one? Or did you just swap the primary wires?
As you describe in first sentence, both.
All wires that come to coils are green. Except ground connections..
37Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Wed Jul 05, 2023 8:33 pm
daveyson
daveyson
Ok I'll have think about it, maybe I should drop out, I try to keep out of K1100 threads, which I'm not familiar with. Something else I was wondering about, you said the injectors are firing good, but your video, it looked to me that nothing was coming out of injectors one and four, but it wasn't easy to see (I'm looking on a small phone)
A quick check is to use a screwdriver as a stethoscope to check that all four injectors are making a good ticking sound
 ~120,000 km
Saints
Saints
I haven’t loaded the video where i test the injectors. But i assure you, they all gave same amount of fuel when tested! I’ll upload it.
39Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Wed Jul 05, 2023 9:41 pm
daveyson
daveyson
Here's the drawing I was looking at, zoomed up. Ignore the green wires, swap the black striped ones as well as the HT leads, and see if the problem moves.
Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Img_2107
 ~120,000 km
Saints
Saints
I think it would be imbossible to ignore green wires, there are no other connections to coils.Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 B6152b10
daveyson wrote:Ignore the green wires, swap the black striped ones as well as the HT leads ...
In the '94 and later models, all primary wires were green.
My assertion would seem to contradict the heading on daveyson's diagram, so here's a different diagram. Let's start a best-of-three coin toss. Smile Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Oi_94_10
43Back to top Go down   Rough and humping idle + ticking sound from the valve cover side K1100RS 1996 Empty Rough humping Thu Jul 06, 2023 5:09 am
daveyson
daveyson
So I'd be trying to identify which green wire is which, with the computer unplugged, or run a temporary jumper wire from the computer to coil 1 to see if the problem disappears, yeah it's probably wishful thinking. I spose the thicker green wires are power and that there's continuity between the two.
 ~120,000 km
