1Back to top Go down   Another K75 Gremlin Empty Another K75 Gremlin Sat Feb 06, 2021 1:35 am
jjefferies
jjefferies
This past Wednesday I dropped by a friend's shop. Got ready to leave, helmet on, earplugs in, I get on my K75 and start it up. Makes an odd whirring sound starting but it does start and with helmet and ear plugs in I don't hear anything too unusual. I hit the freeway and notice that my turn signal indicators aren't indicating, and hi beam indicator isn't indicating either. Choice is to turn back to the shop or continue home. I opt for home. Halfway there the low fuel light comes on. Fine should be able to make it. Bike is doing the usual surging like when the fuel is low and rapid acceleration/stopping causes the gas to roll around in the tank. I get home put it up on the center stand and leave it running. As suspected there were no headlights or running lights, brake light, or turn signals. I turn off the main power switch. Bike keeps running. Sounds like it's dieseling. Uh Oh!. Ok, I now do something stupid and forget about the KILL switch. Just not used to thinking of it. It was like the machine was possessed and refused to stop. So I pop off the fuse cover and remove all the fuses. Bike's still running with weird sound like it's dieseling. I hop up on it, put it in gear, put on the rear brake and let out on the clutch slowly stopping it. Now I think about the kill switch and hit it. Bike is stopped. Wheww! Back on center stand, replace all the fuses, add 1/2 gallon of fuel, turn it on and start it. Everything is normal. Well the clock is reset to 0 as I had pulled its fuse. Test the kill switch. It stops everything correctly. Now I don't know whether I trust this machine. Possessed motorcycles are the worst.  Suggestion is that I give it half a tank and go ride a couple hundred miles to see it it repeats the behavior. Not sure I want to get that far from home. Any suggestions or helpful comments about what to look for?
It had been a totally weird day. Started with the throtle advance/choke light staying on. Turned out the cable had been pinched. Such things I can deal with. And there were other oddities. But demons possessing my bike ....
2Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Sat Feb 06, 2021 1:58 am
Dirty starter motor brushes cause all sorts of weird problems. You can sometimes get a temporary fix by back spinning the starter motor. With the engine off roll the bike backwards in 5th gear and pop the clutch do this a couple of times. However it is best to remove the starter and pull it apart and clean it also check the length of the starter brushes and replace if necessary.
3Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Sat Feb 06, 2021 4:02 am
Suzi Q
Suzi Q
Sounds like it might be your starter relay sticking in. Happened to me once, and it's apparently not uncommon for the k. Something to do with a low battery current allowing the relay contacts to oscillate and weld themselves together. They can unstick - hence the problem seems to cure itself.
The whirring sound on starting might have been the starter continuing to turn. It'll do it during your journey and it wouldn't have been under load whilst the engine was running - the starter freewheel allows that.
Once you try and stop the bike it'll just keep on turning.
Pulling fuses will make no difference, because there's no fuse in the starter high current circuit.
Full beam, indicators won't work because the LS relay will still be de-energised - its coil negative will be at the 12v still on the starter motor terminal.
Hitting the starter relay with a toffee hammer works. A bit.
4Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Sat Feb 06, 2021 7:26 am
Turns it into toffee, does it Chris?
5Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Sat Feb 06, 2021 7:27 am
But yes, I'm with the 'suspect the starter relay/motor' guys. It's easy enough to pop the top off the starter relay and inspect the contacts.
6Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Sat Feb 06, 2021 1:51 pm
Yep, starter brushes and dirty commutator. As long as you have things apart and cleaning stuff, if you haven't done it already, pull the ignition switch and clean it as well. That is another source of strange electrical happenings.
7Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Mon Feb 08, 2021 12:22 am
jjefferies
jjefferies
Thanks for the suggestions guys. I'll leave Silver alone until I can pull the starter and clean it. Which might take a while as I've got a new to me, 1986 K100 project bike. It's been sitting in an apt. garage for the past 10 years and I just got it home and parts are spread about. So will ride the Red K75 for the moment.
J.
8Back to top Go down   Another K75 Gremlin Empty Re: Another K75 Gremlin Mon Feb 08, 2021 6:46 am
Maybe pull the starter motor out of the project bike and refurb it and drop it on. And take the relay too.
It does so very sound like starter/starter relay issue.
Bruce Petterson
Bruce Petterson
jjefferies wrote:This past Wednesday I dropped by a friend's shop. Got ready to leave, helmet on, earplugs in, I get on my K75 and start it up. Makes an odd whirring sound starting but it does start and with helmet and ear plugs in I don't hear anything too unusual. I hit the freeway and notice that my turn signal indicators aren't indicating, and hi beam indicator isn't indicating either. Choice is to turn back to the shop or continue home. I opt for home. Halfway there the low fuel light comes on. Fine should be able to make it. Bike is doing the usual surging like when the fuel is low and rapid acceleration/stopping causes the gas to roll around in the tank. I get home put it up on the center stand and leave it running. As suspected there were no headlights or running lights, brake light, or turn signals. I turn off the main power switch. Bike keeps running. Sounds like it's dieseling. Uh Oh!. Ok, I now do something stupid and forget about the KILL switch. Just not used to thinking of it. It was like the machine was possessed and refused to stop. So I pop off the fuse cover and remove all the fuses. Bike's still running with weird sound like it's dieseling. I hop up on it, put it in gear, put on the rear brake and let out on the clutch slowly stopping it. Now I think about the kill switch and hit it. Bike is stopped. Wheww! Back on center stand, replace all the fuses, add 1/2 gallon of fuel, turn it on and start it. Everything is normal. Well the clock is reset to 0 as I had pulled its fuse. Test the kill switch. It stops everything correctly. Now I don't know whether I trust this machine. Possessed motorcycles are the worst.  Suggestion is that I give it half a tank and go ride a couple hundred miles to see it it repeats the behavior. Not sure I want to get that far from home. Any suggestions or helpful comments about what to look for?
