1 Delete me please Mon Sep 18, 2017 2:10 am
Overture
1984 K100RT (Now Naked)
I've done worse and it only took one off, not four!!charlie99 wrote:well we/ve seen worse
Hmmm. I'm not a fan of that stuff - I use PVC sheathing and plan my wiring looms so that where the wiring branches off, it goes into a smaller diameter tube etc. etc.. No tape anywhere and if properly planned, no exposed wires until they meet the connector. One of the reasons I don't like tape is that if you do make a booboo it's very difficult to un-booboo it. Secondly, taping wires tightly together can lead to heat buildup which is not something you really want.Overture wrote:expanding wrap
Next time you need one (and you will - it's cork and it will disintegrate when you take the cover off) make one from 1.5mm or 2mm rubber sheet instead. Put the cover on the sheet and lean on it to indent the shape, then cut it out. A 6mm hole punch is helpful to -ahem!- punch out the screw holes. You don't have to make a perfect internal shape where the screw holes are either as it's only wires running underneath.gasket for the hall sensor!
K100-forum.com » Your own renovation / customization » cafe racer / custom section » Delete me please
Similar topics
