1Back to top Go down   Post Your Ugliest Hack Empty Post Your Ugliest Hack Sun Apr 19, 2020 10:31 pm
zaubertuba
zaubertuba
Doesn't even need to be a bike hack, but thought it might be amusing (and perhaps helpful, in a dangerous way), to see--what's the ugliest hack you've contrived?
I'll start:
Post Your Ugliest Hack Sideco10
Fugly as sin, but first time I've had the cover on for years, nobody will know, and it should last me at least until I purchase a better used side cover.
1985 K100RS
2Back to top Go down   Post Your Ugliest Hack Empty Re: Post Your Ugliest Hack Mon Apr 20, 2020 1:08 am
Okay, here's mine.  It repairs the pin at the rear of the battery cover.  The one that goes in the hole in the rear cowl.  I broke the pin removing the cover.  I reattached it with a small screw threaded into a hole I drilled in the pin.
I don't have a photo, but on another bike, the battery cover pin was gone.  In that case, I ran the screw into a Blue wiring crimp butt splice.  Post Your Ugliest Hack Dscn2410
3Back to top Go down   Post Your Ugliest Hack Empty Re: Post Your Ugliest Hack Mon Apr 20, 2020 9:32 pm
Post Your Ugliest Hack 20200439
When ready to start Big Block up back in early 2015 (has it really been over five years!?) I realised I'd forgotten about a coolant overflow receptacle. There was a garage-use baby bottle lying about nearby so I snipped off the end of the sucky bit and slipped the tube inside with a splash of BMW blue coolant. A quick tie wrap 'secures' it to the frame rail. I see no reason to replace it now.
4Back to top Go down   Post Your Ugliest Hack Empty Re: Post Your Ugliest Hack Sat Sep 19, 2020 1:16 am
zaubertuba
zaubertuba
One of the three sockets on my mirror bracket broke, so...
Post Your Ugliest Hack Mirbrc10
Hard to see, but I used an old spoke wheel weight as a bushing--the wire passes through the slit so I can tighten the threaded rod down without crushing the wire:
Post Your Ugliest Hack Mirbra10
Probably more secure than it's actually supposed to be!
1985 K100RS
