1Back to top Go down   K100RS gearbox bearing numbers Empty K100RS gearbox bearing numbers Mon Jul 27, 2020 8:02 am
AussieDan
AussieDan
Hi All,
I’ve stripped my gearbox to paint and at the same time I thought I would replace the bearings as they are looking a little second hand!
Does anyone know the bearing numbers for the 6 internal bearings (there looks to be no numbers stamped on the originals)
I want to head off to a bearing shop and hopefully pick some up!
Dan
2Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 8:16 am
Woodie
Woodie
Have you removed all the bearings already?  If you have, and there are no numbers, any good bearing shop will be able to match them up based on measurements and from seeing what series they are.
K100RS gearbox bearing numbers Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
3Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 9:17 am
AussieDan
AussieDan
I’ve removed the shafts and not the bearings yet. I don’t have a press so I was going to try and buy them first before I took them to the shop to swap them over.
4Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 9:19 am
They are very standard sizes and should cost no more that about $100 for quality like Timken or Koyo including seals. The only seal not available is the small one in the rear end of the main input shaft which is usually OK.
5Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 10:15 am
AussieDan
AussieDan
Ok, thanks mate
6Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 11:31 am
K100RS gearbox bearing numbers Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
7Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 11:46 am
6203-2rs x2
6204-2rs x 1
6205-2rs x 1
lm11910  x 1
lm12749  x 1
8Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 9:41 pm
The numbers that Charlie has given have rs in the number which means Rubber shield so you will need to remove the shield and remove the grease. Oil and grease are not compatible and bearing damage can occur very quickly which will shorten the bearing life. I have tried several to get the bearings with a steel shield but have been unable to source them.
9Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 10:09 pm
stanthomas
stanthomas
http://www.wychbearings.co.uk/6203-zz_fag.html
(and all the others too, see search box).
If you want the metal shield, although I can't see why you wouldn't use plain, unshielded bearings here. There're not spec'ed on RealOEM as shielded or sealed.
Wrong side of the world but they will ship.
10Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Mon Jul 27, 2020 10:15 pm
yeah forgot to mention the rubber shield with the 2rs suffix ,
easily removed and degrease the grease out of them so they are plain bearings , the lubrication is generally splash feed inside the gearbox
but they are commonly available from most bearing suppliers
11Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Tue Jul 28, 2020 2:49 am
AussieDan
AussieDan
charlie99 wrote:6203-2rs x2
6204-2rs x 1
6205-2rs x 1
lm11910  x 1
lm12749  x 1
Thanks Charlie,
I gave these numbers to the bearing shop and all good! (without the 2rs)
Total sum of $75!
12Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Tue Jul 28, 2020 10:05 am
K100RS gearbox bearing numbers 112350
13Back to top Go down   K100RS gearbox bearing numbers Empty Re: K100RS gearbox bearing numbers Tue Jul 28, 2020 5:43 pm
As some are aware, with bearing numbers, 'RS' simply means shielded, as in the bearing/grease protector, and most of those are easily removable if not spec'd or required.
