1Back to top Go down   Starter Relay for 85 K100RS Empty Starter Relay for 85 K100RS Fri Jul 03, 2020 9:17 am
GeoffP63
GeoffP63
Hi All,
Can a variation on the OEM starter relay be used successfully?
There seems to be a number of starter relays on eBay that look similar but have various part numbers.
Example are #0 332 002 161  &  0 332 002 168
All are 12v/75 Amp with identical terminals, made in Portugal or Malaysia.
Thanks,
Geoff
1985 K100RS
50,000 Ks
2Back to top Go down   Starter Relay for 85 K100RS Empty Re: Starter Relay for 85 K100RS Fri Jul 03, 2020 10:47 am
There is a diode across the coil of the OEM relay, it needs to be there to prevent a voltage spike when the relay releases. The spike can damage some of the delicate electronic components in other equipment. Some of the aftermarket relays don't have the diode so be careful to choose correctly and don't let the seller tell you otherwise.
3Back to top Go down   Starter Relay for 85 K100RS Empty Re: Starter Relay for 85 K100RS Fri Jul 03, 2020 11:14 am
GeoffP63
GeoffP63
Thanks Rick.
1985 K100RS
50,000 Ks
4Back to top Go down   Starter Relay for 85 K100RS Empty Re: Starter Relay for 85 K100RS Fri Jul 03, 2020 6:55 pm
61 31 1 459 008 is the starter relay's OEM part number, for reference or cross reference purposes. It fits all K75, K100, K1100 & K1.
5Back to top Go down   Starter Relay for 85 K100RS Empty Re: Starter Relay for 85 K100RS Fri Jul 03, 2020 10:01 pm
Some members have added the diode to ones lacking one. I picked up a spare Bosch relay from  Ebay for $39.95 with a $10.00 off voucher. https://www.ebay.com.au/usr/sparesbox_auto?_trksid=p2047675.l2559 I've yet to confirm whether it's correct, so I've included a schematic somebody on the forum will confirm either way.
Starter Relay for 85 K100RS Bosch_11
6Back to top Go down   Starter Relay for 85 K100RS Empty Re: Starter Relay for 85 K100RS Sun Jul 05, 2020 5:16 am
GeoffP63
GeoffP63
Thanks for the advice guys..
1985 K100RS
50,000 Ks
