1 What does this do? Thu Jun 11, 2020 2:49 pm
Stumpy
BMW K100RT 0095857
It is the front offside frame, it comes though the airbox. It looks like it is green / brown, it could be green /redArlina wrote:Seems like ground, need to see more surroundings to make a better answer.What K anyway?
Signature....
Green/brown or green/red do not suppose to have a single connector.Stumpy wrote:It is the front offside frame, it comes though the airbox. It looks like it is green / brown, it could be green /redArlina wrote:Seems like ground, need to see more surroundings to make a better answer.What K anyway?
Signature....
I think mine is blue, it's a straight line from the sensor to the gauge with a kind of bullet connector block halfway which is also blue (I think?). Anyway it's definitely not what OP is asking about!Dai wrote:I've never seen a K100 equipped OEM with the coolant sensor, but I'd expect that to run all the way from the sensor to the gauge with no terminal block in the way, simply because it's an add-on. It would also be a different colour - my money would be on black because that's the only solid colour not used in the loom.
