1Back to top Go down   Stuck speedo and rev counter Empty Stuck speedo and rev counter Tue Apr 21 2020, 12:14
JGT
JGT
Was riding with the sun behind me today with full glare on the instrument pod. The rev counter froze and the speedo became very sluggish. Eventually with change of direction, back  in the shade and within seconds normal service resumed. The fault re appeared when exposed to the sun again. What would cause this, its never happen'd before.
1992 K75
2Back to top Go down   Stuck speedo and rev counter Empty Re: Stuck speedo and rev counter Tue Apr 21 2020, 16:50
Had the same issue some years ago where the temperatures frequently got to the mid 40s C. The speedo face warped and the needle got stuck at different angles and different times of the day. The tacho needle got stuck on the glass/plastic every now and then. Good luck.
3Back to top Go down   Stuck speedo and rev counter Empty Re: Stuck speedo and rev counter Tue Apr 21 2020, 17:50
I fixed my tacho needle sticking last week, it was hitting the glass. It had been sitting in the sun before it happened.
4Back to top Go down   Stuck speedo and rev counter Empty Re: Stuck speedo and rev counter Wed Apr 22 2020, 10:32
JGT
JGT
Thanks for the reply's. Nothing really to worry about.
1992 K75
5Back to top Go down   Stuck speedo and rev counter Empty Re: Stuck speedo and rev counter Wed Apr 22 2020, 12:18
MY K1100RS speedo also does this but only when sun is shining. Normally in Ireland this is not an issue  Cool
I don't think the needle is catching but something in the internals. The speedo will stick and stay about 80kmh.
Stuck speedo and rev counter Ir-log10
 ;BMW; K1200RS Red
6Back to top Go down   Stuck speedo and rev counter Empty Re: Stuck speedo and rev counter Wed Apr 22 2020, 12:53
Ringfad wrote:MY K1100RS speedo also does this but only when sun is shining. Normally in Ireland this is not an issue  Cool
That usually sorts itself if you change up into second gear  (o)
