1Back to top Go down   1985k100 Empty 1985k100 Thu Aug 20, 2020 12:46 pm
Noel1985k100
Noel1985k100
This from mechanic
Any ideas? I have read previous threads...if I missed something please direct me
“ Lol I was gonna text you
I got the injectors Freed up and pulsing when a battery is put to them and the rail has fuel pressure so they do spray but it doesn't spray when the motor turns over and we don't have spark when the motor turns over. Have to track down if that's a relay And I've been reading the book you sent me. It's one of those weird things when the motor turns over 3 turns and stops for a couple seconds and then turns over again you do have spark at the plugs but then when the motor just terms over freely there's no spark never in my life have I seen this before of course”
2Back to top Go down   1985k100 Empty Re: 1985k100 Thu Aug 20, 2020 1:49 pm
Have you neutral light showing? You need that or else pull the clutch lever, assuming the switch on the lever is good.
3Back to top Go down   1985k100 Empty Re: 1985k100 Thu Aug 20, 2020 3:56 pm
Would start with cleaning all connectors and both earthlines, 1 is leftside on the gearbox, and there is a bunch under the tank together.
1985k100 Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
