1Back to top Go down   Tacho needle wavering Empty Tacho needle wavering Fri Apr 03, 2020 11:36 pm
G'day All,
My 1986 K100RT  (ex police) also known as the Goulburn bike, has developed a problem with the tacho needle fluctuating widely at a constant speed.
So far I have checked that the two long plugs into the cluster are seated properly and that there is continuity in the red/blue wire from the coil to the plug at the cluster.
The other thing may be that the needle is not seated correctly on its pin.
Any thoughts on thiss little issue would very much appreciated.
Tom
2Back to top Go down   Tacho needle wavering Empty Re: Tacho needle wavering Fri Apr 03, 2020 11:43 pm
Pull the sensor out and clean it. It's in the rear drive you need a 4mm Allen key and lever it gently out then check the surface it will probably have some iron residue build up on the face. it comes from normal wear on the gears
3Back to top Go down   Tacho needle wavering Empty Tacho Needle Wavering Sat Apr 04, 2020 12:32 am
Thanks Rick, the speedo needle was also wavering and I have cleaned the sensor which was pretty grotty.
The Tacho needle is the problem. There is continuity for the red/blue wire from coil to plug and continuity for the earth wires from plug to frame.
Before I delve any further I'll for any other replies.
Tom
4Back to top Go down   Tacho needle wavering Empty Re: Tacho needle wavering Sat Apr 04, 2020 12:41 am
The tacho picks it's signal from one of the coils. It could be a faulty/dirty connection.
5Back to top Go down   Tacho needle wavering Empty Tacho Needle Wavering Sat Apr 04, 2020 1:05 am
Thanks Martin,
The coils are new and the red/blue wire ( the signal sender from the coil) connection is tight and clean.
Tom
6Back to top Go down   Tacho needle wavering Empty Re: Tacho needle wavering Sat Apr 04, 2020 1:40 am
If the needle gets loose it will fall off completely so that is not your issue.
Connection where the connector on the back of the cluster connects to the pin?  Make sure that the female terminal in the connector has not been pushed in.
Also try to trace the tach wire inside the cluster to see if you can find a flaky connection there.
7Back to top Go down   Tacho needle wavering Empty Tacho Needle Wavering Sat Apr 04, 2020 1:54 am
Thanks Duck,
Opening the cluster is my next step. I'll keep you posted.
Thank you all for your input.
Tom
8Back to top Go down   Tacho needle wavering Empty Re: Tacho needle wavering Sat Apr 04, 2020 5:57 am
The other thing that I have seen is the wee coil spring wrapped all out of shape. A gentle dig with a jeweller's screwdriver sorted that and stopped the needle bounce (speedo, as it happens).
9Back to top Go down   Tacho needle wavering Empty Re: Tacho needle wavering Sat Apr 04, 2020 11:21 am
Is there any misfiring?  A faulty Hall Sensor signal could be causing the problem.
10Back to top Go down   Tacho needle wavering Empty Tacho Needle Wavering Sat Apr 04, 2020 6:02 pm
Thanks Dai and Point-Seven-Five,,
There is no misfiring. The engine is running as sweet as a nut, just ask Waz.
I'll be delving into the cluster today and check out Dai's wee coil spring. I'll keep you posted.
Tom
11Back to top Go down   Tacho needle wavering Empty Re: Tacho needle wavering Sat Apr 04, 2020 6:21 pm
Does the fluctuating ever settle down or is it constant.
12Back to top Go down   Tacho needle wavering Empty Tacho Needle Wavering Sat Apr 04, 2020 7:13 pm
Hi Martin, the fluctuation is pretty constant. Even at idle the needle moves around a lot more that normal.
Tom
