1 '85 K100 - Won't Come Off Idle Thu Jun 09, 2011 3:22 am
Nixels
Hi Kbikers! I'm introducing myself with this thread. My particulars will come out as I describe the issues encountered.
I bought an '85 K100RS that hadn't run in a couple years.
I signed up here to get some technical input so I could navigate its ills and have done well enough to get the bike started.
I replaced the fuel pump (having checked it first - defunct) with a Ford pump as described in a post here.
My apologies - I don't have the links now, I did most of this work a couple months ago.
Getting fuel to the rail, Mr. Injector-cleaned FIs, changing spark plugs, new battery - and cleaning the starter of carbon so that I have full spark brought me to the point where I could attempt a start of the bike.
A lot of oil past the rings - sat on side stand for who knows how long? Took about 10 minutes of running at idle to get it running clean. :pale:
As you'll see in the video, I can't get the bike off idle without a can of starter fluid. I did try this later with the intake funnel in place, but to no avail.
Having performed the electronics diagnostics, I am stumped. I think it might be the throttle position sensor, but it doesn't clean up when I detach the plug for that at the back of the fuel rail.
I've kept this description brief - thus leaving out things that you may ask if I've done. Fire away, I'll let you know - but I'm stumped by where to go next.
Thanks for the site!
