1 Massive thanks to Bert! Thu Feb 17, 2011 7:56 pm
I'd just like to say a heartfelt thank you to Bert for the magnificently colourful K100 wiring diagramme. After much sodding about with the woeful attempt Clymer put together, it was the colour coding in Bert's diagramme that allowed me to trace what was wrong with hazard/display/flasher problem I'd been wrestling with for a few days. Apparently, one of the previous owners "repaired" the hazard switch, but when soldering the connections put the earth on the wrong terminal. Given that this switch was seldom used, I never thought to test it, but lo and behold, when I pulled the bugger off the dash pad, and scraped away the layers of silicone sealer, I found the earthing wire in position 3 instead of in position 1. A quick application of soldering iron, solder removing gun, and new solder has remedied the problem and now my dash glows like a festivus tree! Cheers Bert!
