1Back to top Go down   There is a hole in my bucket. Empty There is a hole in my bucket. Thu Mar 19, 2020 10:17 pm
Canadakbike
Canadakbike
Out for a good prance about on my K100.
My buddy on an R3 gave it a rev while waiting for the light to change.
Off we went then I felt the power cut out.... the back on.
Took it to a big parking lot and same thing. Under steady but hard acceleration the engine cuts for a second or 2 then back on. Feels as though the injectors cut to prevent redline but know where near.
Anyone have any thoughts?
2Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Thu Mar 19, 2020 10:35 pm
Sounds like an air leak between the MAF and manifolds on the head.
3Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Thu Mar 19, 2020 10:37 pm
Air leak.  Z tube between airbox and crankcase breather?  How old is it?
4Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Thu Mar 19, 2020 10:41 pm
Gas tank connector starting to fail?
5Back to top Go down   There is a hole in my bucket. Empty All good suggestions Thu Mar 19, 2020 10:54 pm
Canadakbike
Canadakbike
I still beat the r3 incidentally.
I like the idea of an air leak as the bike has been running rich.
Don’t know what a Z tube is but, I’ll look at figuring out.
Is there a possibility of the pressure reg. Not performing properly?
When the power cut the rpms drop the power comes on again without further interruption.
6Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Fri Mar 20, 2020 8:07 am
moriarti
moriarti
I had a similar fault on mine after months of hair pulling  Crazyfrog id the problem
Ignition Control Unit mounted under the tank/front of frame,replaced with S/H
unit runs perfect.Hope this helps.
7Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Fri Mar 20, 2020 8:43 am
moriarti wrote:I had a similar fault on mine after months of hair pulling  Crazyfrog id the problem
Need PO to state year of his K bike as some RS are 2v. There is no ICU on the 4v engines.
But early K100 gas tank connector is a suspect high on the list.
8Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Fri Mar 20, 2020 9:58 am
92KK 84WW Olaf wrote:Need PO to state year of his K bike as some RS are 2v. There is no ICU on the 4v engines.
It's a 1990 RS.
Click on the Profile tab on the top of this page and enter your moto's model and year in the Signature section, Canadakbike, so members won't need to chase around looking for it.
9Back to top Go down   There is a hole in my bucket. Empty Thanks Laitch Fri Mar 20, 2020 11:11 am
Canadakbike
Canadakbike
Done,
thanks for the guidance
1990 K100 RS ABS 4valve
10Back to top Go down   There is a hole in my bucket. Empty Tank connection Fri Mar 20, 2020 11:20 am
Canadakbike
Canadakbike
Olaf are you referring to the hose crimp connector at the tank?
The power drop and pick up are immediate. During the power down applying more gas does nothing. When the power comes back on arms rip off.
Replaced plugs this morning. I had new ones for this season. Raining now so will wait till later to test. Going over other suggestion now.
11Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Fri Mar 20, 2020 11:22 am
Check the four pin fuel tank/pump connector.  Major source of power on/off engine issues.
12Back to top Go down   There is a hole in my bucket. Empty Re: There is a hole in my bucket. Fri Mar 20, 2020 11:39 am
92KK 84WW Olaf wrote:But early K100 gas tank connector is a suspect high on the list.
Later ones fail too. I know of a few K1100s where that happened.
