1Back to top Go down   Alternative fuel pump holder Empty Alternative fuel pump holder Fri Feb 07, 2020 9:17 pm
Packo
Packo
Before I bite the bullet and order one from one of the usual suppliers. has any one sourced a cheap (but good of course) version of the fuel pump damper.
Looking for either a cheaper alternative or a satisfactory way to fix the fuel pump into the plastic suspension ring, failing that I will have to spend the $$$$
Alternative fuel pump holder Fuel_p12
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
2Back to top Go down   Alternative fuel pump holder Empty Re: Alternative fuel pump holder Fri Feb 07, 2020 10:41 pm
What ever you use will have to be fuel proof. Go to a car wreckers and get an old filler neck hose of the correct diameter. You should be able to secure it in place with a combination of fuel hose and stainless ties. You could also try the BM shop in Brisbane or Motorworks in the UK.
3Back to top Go down   Alternative fuel pump holder Empty Pump Sat Feb 08, 2020 12:19 am
daveyson
daveyson
I wrapped a fuel hose around one of my pumps and tightened it up with a zip tie inside. I dare not recommend a colour other than black. Dunno what they say about zip ties in fuel but they seem hard enough. It then sits on top of the bracket.  You could put one under too I spose.
Or maybe even slit it down the guts and fit it over the ring, maybe don't need the zip tie then.
 ~120,000 km
4Back to top Go down   Alternative fuel pump holder Empty Re: Alternative fuel pump holder Sat Feb 08, 2020 2:13 am
volador
volador
tills.de most economical of the K-bike vendors although always shipping $ to consider. DHL shipping is excellent no issues
https://www.tills.de/bmw-k75-74/tank-224/
5Back to top Go down   Alternative fuel pump holder Empty Re: Alternative fuel pump holder Fri Feb 14, 2020 12:31 am
brickrider2
brickrider2
Check this out:    https://www.ebay.com/itm/BMW-K1-K100-K1100-K75-1984-1997-Fuel-Pump-Filter-16121461576-16121460452/382307941512
It's tough to imagine a better deal than that.  On offer is most of the stuff you find housed withing the tank!  -- and at a very economical price. I'm thinking I may buy this simply to have it on hand for future needs.
1996 K1100LT
6Back to top Go down   Alternative fuel pump holder Empty Re: Alternative fuel pump holder Fri Feb 14, 2020 4:33 am
At U$82 inc. shipping I'm pretty tempted too.
