1 Ignition Switch/Lighting Issues Mon 30 Dec 2019, 07:38
G'day All, Replaced the original ignition switch (badly burnt/damaged) with one I had hanging around the spares box. The connector plugs were different the original being white and triangular and the replacement black and squarish. The wiring colours were the same on both plugs. I cut off both plugs and soldered the original
plug onto the replacement ign. switch.
The problem now is that only the parking light comes on when using the handlebar switch. No headlight, or high beam. Fuses are fine.
I suspect it is an issue in the handlebar switch not being compatible with the new ignition switch.
Thank you in advance for any clues.
Tom
Tom
