1 The Trouble with Murphy Sun Jan 26, 2020 9:25 pm
After 2 weeks I'm still trying to scrub in my new rear tyre. I'm suffering from Murphy's Law number 126. I had a new rear tyre fitted but they couldn't balance it as it didn't fit on their machine. The suggested a car tyre place and gave me some weights. I tried Bridgestone where we get our car tyres, the wheel centre hole was too small, they suggested Yamaha up the road. Yamaha said they would do it while I waited, however it didn't fit their machine and they then suggested Bridgestone. I gave up and went off to the Trades Guild and made up a blade type static balancer which proved a bit sensitive and finicky but it worked. I'll convert it to a four bearing type after I sort all the other things out.
In the meantime every time I went to scrub in the tyre it rained, but no complaints as we need rain desperately. So while I was waiting, one thing has led to another. New tyre led to the fact you should do a rear spline lube, which led to exposing a leaky pinion seal and a popped drive shaft clip. This requires the removal of the drive shaft housing which exposes the GPI switch which has a intermittent fault. I have a spare so I can either clean it or replace it. So while I'm this far in I might as well slide the gearbox back and lube the clutch splines. As it's Australia day long weekend nothing is open. So tomorrow when I go to the Trades Guild I'll make the pinion retaining nut socket and the hold plate. Then come home and order the parts required. in the meantime I might as well start stripping it down.
