1 SOLVED: K100 Radiator flush or thermostat change to tackle heat problem Wed Aug 04, 2010 1:20 pm
Hi,
Since fitting the RT fairing, I've been plauged with heat problems. When I ran the motorcycle in its RS guise, the bike would heat up but the radiator cooling fan managed the heat admirably. The temperature would be brought down and the fan would cycle properly.
With the RT, heat builds up a great deal more and a great deal faster. I am aware of the heat issues with the RT series but this problem is more I believe. The temperature can be maintained if I keep the bike at speed. If I encounter stop-and-go traffic, the bike overheats. The cooling fan will engage when the temperature rises enough to trigger the fan relay. But the fan cannot seem to cool the fluid and eventually the overheat light comes on. I have to turn off the bike to prevent damage to the engine. I would expect that the fan would provide enough air flow to maintain or lower the temperatures...but it doesn't. Even after getting past stop-and-go traffic, the temperature takes a very, very long time to lower.
The fan is brand new. The fan circuit functions normally and correctly. I have changed the cooling fluid twice this year. I use 50/50 mix of water and BMW anti-freeze recommended by BMW for this engine (aluminum block). I have kept the radiator area meticuliosly clean so there is no air flow blockage. I don't have any Kguards or reflective material to redirect or trap heat.
So given all this state of affairs, the only thing I can think of that might be problematic is the thermostat. It is the original thermostat from when I bought the bike. Should I replace it as a matter of course?
Another thing is a radiator flush. I've never done one and don't believe one has been done ever. Will this flushing help to remove scale that may be inhibiting thermal transfer? If so, how do I do a rad flush (I have no idea)?
Thanks for any other suggestions that you may have to help my heat problems.
Cheers,
Cheers,
