Number of posts : 4223
Are you sure you have the fuel lines connected to the correct spigots on the tank? You wouldn't be the first one to connect the hoses to the tank incorrectly.
Disconnect the fuel supply hose from the tank to the rail and direct the flow into a bottle. Hit the start button and see if anything comes out. If it flows, you may have the regulator connected backwards.
The regulator is a poppet valve and connecting it backwards will block the fuel flow through it.
If there is no fuel getting to the rail the problem is not in the regulator.
