1Back to top Go down   K100 '84 permanent Neutral Light Empty K100 '84 permanent Neutral Light Fri Jul 17, 2020 10:10 am
ady954
ady954
Hi  Guys, looking to purchase an '84 K100 this week. However, I'm a tad concerned about the permanent neutral light on display. I am assured the bike runs A1 through all gears. The gear select indicator works ok. The owner suggests the gear sensor/indicator switch may need replacing. Would a broken gear sensor be consistent with this problem? I'm thinking a broken neutral wire on loom or faulty instrument panel.
Any help much appreciated. K100 '84 permanent Neutral Light 212902
2Back to top Go down   K100 '84 permanent Neutral Light Empty Re: K100 '84 permanent Neutral Light Fri Jul 17, 2020 11:43 am
If you see the gears in the indicator, the sensor is good.
It's somewhere in the instrument cluster where the defect finds place.
K100 '84 permanent Neutral Light Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   K100 '84 permanent Neutral Light Empty Re: K100 '84 permanent Neutral Light Fri Jul 17, 2020 11:54 am
ady954
ady954
Ahh, thanks for that. I did think it strange. This should not inhibit my plans as I intend changing the clocks. Much appreciated.
4Back to top Go down   K100 '84 permanent Neutral Light Empty Re: K100 '84 permanent Neutral Light Fri Jul 17, 2020 12:34 pm
The bugger seems to be 1 of these 3, or all....
https://www.kforum-tech.com/electrical/neutral%20light%20board.jpg
5Back to top Go down   K100 '84 permanent Neutral Light Empty Re: K100 '84 permanent Neutral Light Fri Jul 17, 2020 12:37 pm
moriarti
moriarti
Arlina from what you say am i right to think that if the gear indicator and neutral light stop working intermittently its most likely the gear indicator switch at fault. scratch Not the panel. Very Happy
6Back to top Go down   K100 '84 permanent Neutral Light Empty Re: K100 '84 permanent Neutral Light Fri Jul 17, 2020 12:54 pm
Ady mentioned the indicator works....
If the indicator and light don't work, or not normal, it could be the gearselector, but better start cleaning the connector on the right side.
7Back to top Go down   K100 '84 permanent Neutral Light Empty Re: K100 '84 permanent Neutral Light Fri Jul 17, 2020 1:09 pm
moriarti
moriarti
Arlina wrote:Ady mentioned the indicator works....
Thanks Arlina your a Sweetheart K100 '84 permanent Neutral Light 723598
